Fork/shock options
1 reply to this topic
  • toten
Posted February 17, 2015 - 08:29 AM
I have a 2003 WR450F that's been set up for supermoto. I believe the forks have been resprung and revalved, the rear shock has been revalved and shortened as well.
I'd like to keep it a supermoto most of the time, but every now and then I would like to ride dirt. I suspect supermoto suspension won't work too well for trails, so I'd like to pick up a set of forks and a shock for when I ride dirt - I know forks are easy enough to swap, I don't imagine a shock is too horrible either.
What all is compatible, and is there a specific setup I should look for? I'd prefer not having to swap triple clamps, instead I'd rather just drop the forks. I'm guessing that any WR or YZ 400 and 426 forks/shock will work, and then any steel framed 450, but I could be wrong. I'm around 180lb + gear, and would prefer not respringing if I don't have to.
Thanks for any advice.
  • stevethe
Posted February 17, 2015 - 11:17 AM
I think it is a bit of a hassle to change the rear shock. You should just try what you have and see if it's okay in the dirt.
