2014 pipe on a 2012?
4 replies to this topic
  • haydug
Posted February 10, 2015 - 07:41 AM
Has anyone tried this yet? I have a buddy with a 12 and he wants my stock 14 exhaust. Not sure if there is room between the radiators. As far as gabbing mounting brackets I can handle that. Just figured if someone here has tried it and no way possible it would save him a 3hr drive and both of us time on fab work. Thanks
  • 250premixer
Posted February 10, 2015 - 09:22 AM
Probly won't fit around the cylinder and it has no mounting points
  • WouldsAssassin
Posted February 12, 2015 - 07:00 PM
I've heard the radiators are different, the ignition parts have been moved and the subframe is very different. All are to accommodate the wraparound exhaust.
Posted February 12, 2015 - 08:30 PM
Moving the ignition components might have been. Not the other stuff.
  • ratom98
Posted February 15, 2015 - 08:35 AM
moving the ignition equipment coming out of the front of the motor is the biggest problem. might also have to move the radiator fitting on the bottom of the left radiator.
  • 0 replies
  • Hot  36 replies
  • 10 replies
