rer shock linkage needle bearings question
3 replies to this topic
  • SurfaceToAir
Posted February 06, 2015 - 10:38 PM
I have the rear linkage apart- putting the shock back in.. The needle bearings in the linkage attached to the swing arm -closer to the tire, are falling out as I try to assemble the linkage..
Should I replace the whole two bearings or pick up the bearings ( hopefully all) and pack them full of grease and finish the install?
thanks!
Dustin
  • mdsharon
Posted February 07, 2015 - 01:59 PM
thanks!
Dustin
Yes they will fall out put them back in with some good moly grease they  will be fine
  • Mtrain730
Posted February 07, 2015 - 02:07 PM
That seems odd. I admit my knowledge on wrenching on dirt bikes is limited but I have never had the needles fall out after cleaning and greasing them. If the bearing race is not worn and the needles are in good shape. I would just put them back in and try again.
  • SurfaceToAir
Posted February 07, 2015 - 05:28 PM
Thanks guys. I'll just put them back in. I called the shop and a rebuild kit was $90. There is some light corrosion on the inner bushing where the bolt goes through , etc so I'll dig back into this soon, but am more interested in getting it on the trail this weekend.
Cheers!
  • 9 replies
  • 0 reviews
