07 WR450F GPRV4 Stabilizer Install Problem (Help!)
9 replies to this topic
  • SmackIt
Posted January 31, 2015 - 12:14 PM
I have a lot to do this weekend...
The first thing I try to do is the GPRV4 Stabilizer Install. Should be a piece of cake, right?
The flats on the pin are slightly off center.  Is that correct?  I guess it could be?
Put the ring on and it's not flush.
There are two little post type protrusions on the cast steering column with two machined areas on the GPR ring.
Left Side Looks Good
But right side is not...
I assume squeezing the ring together will bring them closer, but the screw bottoms out and the ring can not be closed more.  Flaw or feature???  It looks to me like this hole was not completely tapped???
I tried using a shorter screw so I could pinch the ring closer together, but the ring doesn't close enough to make a good fit on those posts.
Has anyone installed one of these and did you have a similar experience?  Of course it's saturday and GPR is closed, so I can't call and find out what the problem is.
  • Krannie McKranface
Posted January 31, 2015 - 03:28 PM
Typical.
GPR is not all that precision in my experience. Mine had to be 'tweaked' to fit.
Filing the frame is common for a proper fit for GPR and Scotts anyway
Remember, it's not structructural, so you can modify it as long as it's on tight.
  • KennyMc
Posted January 31, 2015 - 03:43 PM
As Bill said, just file the frame.
Posted January 31, 2015 - 09:55 PM
File it under " KTM EATER"
  • KennyMc
Posted January 31, 2015 - 11:21 PM
Typical Yammi crap :-)
Posted February 01, 2015 - 09:45 PM
Typical Yammi. Beats the crap out of everything.... :-)
  • KennyMc
Posted February 01, 2015 - 10:03 PM
Dooood, I LOVE the 300.  Sooooo much fun, right up to the point I went through the bush and got separated from it and twisted my knee :cry:  :cry:
Posted February 02, 2015 - 06:13 AM
So, you are saying that it's sooo good that it won't turn and avoid trees?
  • KennyMc
Posted February 02, 2015 - 07:05 AM
The decision was go into a rain rutted trail or a bush. Split decision. As a man, I always chose bush. ;)
This bush ate me alive :shocked:
Further details on riding area specifics are classified and are on a need to know basis :devil:
  • bobpara
Posted February 02, 2015 - 07:32 AM
I just put a Scotts on mine recently, very similar
1) Definitely grind the frame so that ring sits on there nicely. A file is OK, but a dremel will work nice for the finnish work
    The carbide 'tile cutting' bit works really good on metal, for finnisgh work use a coarse grit sanding drum
    IT IS ESSENTIAL TO REMOVE 100% OF THAT BUMP OR THE CLAMP WILL NOT HOLD TIGHT
2) As far as that flat goes, rotate it. Work holding is essential to success. A pair of wood blocks in a vice to hold the clamp
    Get a wrench that matches the flats and gently rotate. If it is loose in any way afterward you will need to press it out .
    'scar' the shaft with a diamond file or something to make shaft 'fatter' and re-press. In addition poss use some forever loctite
    Another possibility is just simply return to them and get one that is right
Good eye. Both of those are important
