2014 wr450 fork 'sag' question
5 replies to this topic
  • iggs
Posted January 29, 2015 - 06:32 AM
Ok, please bear with me I'm a n00b
I get my new WR this weekend hopefully and I've been reading everything I possible can about the bike particularly with regard to suspension set up
But
I don't seem to have read how to set fork sag. Could someone point me in the right direction please
  • AtomicGeo
Posted January 29, 2015 - 06:54 AM
I am assuming you already set the rear spring static and race sag at 100 to 104 mm correct?
Fork sag is usually talked about in mountain bikes...I've not hidden much or at all in motos.
  • iggs
Posted January 29, 2015 - 07:18 AM
My back ground is Mtb so that's probably why I'm asking
But
My understanding is that correct rear sag helps set correct steering geometry. If the front sag is incorrect then that will affect the steering adversely
Is the only way to do it via spring weight and changing springs?
  • GuyGraham
Posted January 29, 2015 - 11:09 AM
Fork sag is notoriously difficult to measure due to the stiction in the forks - you will find you get a different reading every time
However here are some numbers for you
Dirt Bikes         SAG
Front (300mm travel)
Static (Free) Sag (60-70% of Rider Sag) 45 - 63mm
Dynamic (Rider) Sag (25-30% of Full Travel)     75 - 90mm
Loaded Sag - (Dynamic Sag - Static Sag)     12 - 45mm
Rear (300mm travel)
Static (Free) Sag (15-25% of Rider Sag)     25-35mm
Dynamic (Rider) Sag (25-30% of Full Travel)     90-100mm
Loaded sag (Dynamic Sag - Static Sag) 55 - 75mm
You are better off judging by the amount of travel you have left after a typical ride
Forget preloading the springs, was you want very little preload on the springs (<5mm), so that when the bike is very light on the front, the fork springs aren't push the wheel off the ground
Edited by GuyGraham, January 29, 2015 - 11:10 AM.
  • yamahadude93
Posted February 01, 2015 - 02:06 PM
Did I read this right?
  • iggs
Posted February 01, 2015 - 05:31 PM
what did you read?
