how many hours on a piston 09 yz 450
18 replies to this topic
  • roosted1
Posted January 26, 2015 - 02:20 AM
hi , I have recently purchased a 09 yz 450 , has now 73 hrs on it since new and has never been apart . to me it sounds very noisey like it might be due for a piston ,and it is noiser than other bikes I have heard  . how may hours roughly should you get out of one of these bikes  piston before it needs changing ?
this is my first 450 had 2 strokes before this one
Posted January 26, 2015 - 07:36 AM
It depends on how you ride it, and on how you maintain it.  I changed mine out at right around 300 hours of desert racing and recreational riding.  The only way to really know one way or other is to pull it apart and look.
  • roosted1
Posted January 26, 2015 - 12:11 PM
ok thanks grey , bike has been very well looked after and maintained , very fussy owner , bike was used for enduro style racing here in Australia , 300 hrs is a lot more than mine has done
mine also has a after market bash plate which could be radiating a bit more noise too ,
  • Thommo_400f
Posted January 26, 2015 - 04:43 PM
Might be chain slap.... has tricked me before!
  • roosted1
Posted January 26, 2015 - 11:04 PM
nah , its when its just sitting there idling
  • x_JT_x
Posted January 26, 2015 - 11:06 PM
Yes, it might be chain slap. Cam chain slap. Which is very noticeable on idling bikes
  • roosted1
Posted January 27, 2015 - 02:52 AM
yep I'm an idiot ! :rolleyes:  sounds more solid than a cam chain rattle , sure its piston slap , its a lot louder engine noise than my friends 06 rmz 450
so perhaps I should be asking is there a recommended time to pull down and check things ?  50 hrs ? 100hrs ?
  • cowboyona426
Posted January 27, 2015 - 08:09 AM
Do you have an aluminum skid plate on that bike?
  • jrice2012
Posted January 27, 2015 - 09:17 AM
Pull the clutch in... My transmission makes a loud noise. Pretty sure all these bikes do. At 75 hours If you haven't abused it it should be fine. Pull the clutch in at neutral and see if it still makes it
  • roosted1
Posted January 27, 2015 - 12:16 PM
yeah it has , its not a huge one just a bit bigger than std. I will remove it and have a listen . I have a B & B skid plate on my drz 400 and that makes a huge difference to the engine noise
  • n16ht5
Posted January 27, 2015 - 01:37 PM
yeah it has , its not a huge one just a bit bigger than std. I will remove it and have a listen . I have a B & B skid plate on my drz 400 and that makes a huge difference to the engine noido a leakdown test
Do a leakdown test
Posted January 27, 2015 - 04:19 PM
Unfortunately, leak down tests don't really say too much about the piston itself.  The rings may seal pretty well in spite of the fact that the piston is perhaps even dangerously worn.  This was somewhat the case with my own '06.  Ran fine, good compression, and not even any unusual noise, but the piston was actually a bit overdue for replacement, going by the wear I found.
The other earlier point about the gearbox rattle is quite valid.  Read: http://www.thumperta...e/#entry4444207
  • Thommo_400f
Posted January 27, 2015 - 04:26 PM
My Piston is being done as we speak... 150hrs
Was starting to seem noisy.
Slightly down on compression.
Piston was showing wear on sides and rings were very worn (probably making the piston wobble).
Caught it before any marks or wear on bore.
$700 for piston/rings/gaskets and labour.
I say if you are concerned...do it and then ride happy.
  • x_JT_x
Posted January 27, 2015 - 05:38 PM
That's a $200 Job if you do it yourself.. Would probably take you 3 hours your first try and then 1 and a half the second try. I don't know about you but I sure won't pay hundreds per hour for work..
  • Yzrider1023
Posted January 27, 2015 - 08:34 PM
Yamaha's are generally noisier bikes in my experience but by now it might be due for atleast a partial top end piston,rings,head gasket
  • roosted1
Posted April 25, 2015 - 04:07 PM
Have tried this and it's much quieter with the clutch in ,almost to the stage where I'm thinking something in the clutch might be loose .might pull the clutch cover and have a look
  • jrice2012
Posted April 25, 2015 - 04:09 PM
The tranny is just noisy man. It drives me crazy. But every single yzf I've ridden of that generation has the same rattle noise
  • Limagrunt0331
Posted May 04, 2015 - 11:23 PM
Would you expect to hear this on a new 15 YZ250f? This is literally keeping me up at night. Lol.
  • jrice2012
Posted May 05, 2015 - 08:06 AM
Ahhh. No idea man. Haha I haven't noticed anything out of my buddies 15 though
  • On January 15, 2017
  • 9 replies
  • 0 replies
  • Hot  113 replies
  • Hot  47 replies
