'09 too snappy just above idle. How do I tame it down?
27 replies to this topic
  • Navaho6
Posted January 19, 2015 - 06:13 PM
I'm using this bike for woods riding and the only real gripe I have is that it is a little to snappy right above idle. Just twisting the throttle slowly, rpms jump up so quickly, like a switch being flipped.  My WR's weren't like this.  What is the cause and the cure?
  • billygildark5007
Posted January 19, 2015 - 07:15 PM
I believe that the cause is you have a mx bike that wants to rip and power on. I don't know if there's anything that could be done to the carb that's really beneficial for that jerk. Maybe a wr tranny (did in my 04). I think your best option would be a flywheel weight.... Others might know other tricks.
Edited by billygildark5007, January 19, 2015 - 07:22 PM.
Posted January 20, 2015 - 07:27 AM
So, does this engine ever pop or crackle through the exhaust on decel? If not, your problem may be that it's been set up too rich on the pilot circuit as an incorrect fix for a bog or whatever.  That can lead to a sloppy off-idle transition.  If this is your first YZ450, and you were used to a WR or something, some degree of this is just the nature of the YZ, but you should be able to get a smooth, linear transition from it if it's tuned right.
  • Navaho6
Posted January 20, 2015 - 05:14 PM
Thanks gray.  Yes, it is my first YZ.   I have not noticed any popping on decel.  So I guess I could try a smaller pilot. Anything else I can do?
  • Chas_M
Posted January 20, 2015 - 06:19 PM
Check out the G2 'throttle tamer'.  Many folks swear by these.  The G2 is available with a variety of cams to slow down the initial throttle response.  Another option is to add a flywheel weight.
Posted January 20, 2015 - 07:59 PM
Start by finding out whether that's the problem the easy way:
http://www.thumperta...ircuit-setting/
The popping thing is just an indication.  If you ignore the exhaust and set the bike up so it runs the best it can in terms of how well it idles, most YZ450's will pop "some".
  • Thommo_400f
Posted January 21, 2015 - 03:35 PM
I know what you mean...
My mates KLX450R has been race tuned by a pro... when I ride it in the tight stuff it nearly kills me because it is so instantly responsive. No issues, just wants to gooooo!
I think the throttle cam would be the first choice, then it's easy to swap out if you go into some wide open stuff.
  • jrice2012
Posted January 21, 2015 - 06:00 PM
You could try an 08 cdi box.. There powerband (lol) was much more mellow and more manageable. They were almost considered weak. But they aren't. They are just way easier to control.
  • Gunner354
Posted January 22, 2015 - 07:31 AM
08&09 cdi should be the same. Check to see if you have an 06,03 or 04 cdi
Edited by Gunner354, January 22, 2015 - 07:34 AM.
Posted January 22, 2015 - 07:33 AM
Maybe they should, but they aren't.
2008: 2S2-85540-B0-00
2009: 34P-85540-00-00
  • jrice2012
Posted January 22, 2015 - 09:35 AM
Does this make me right? B)
Posted January 22, 2015 - 10:50 AM
About there being two different ones?  Looks like it.
  • mdsharon
Posted January 22, 2015 - 10:51 AM
Put in a rekluse3.0 exp tames it down and is awesome in the woods.
  • Hoosier-Daddy
Posted January 22, 2015 - 11:26 AM
The heavy flywheel helped smooth the power out on my 09. Little over 100$
  • Navaho6
Posted January 22, 2015 - 06:12 PM
I have a flywheel weight and a WR450F header on the bike.  I don't mind the snappy power except in 1st gear.  The bike goes from idle to revving in 1 mm of throttle travel.  I've been told that this is a YZ trait.
Edited by Navaho6, January 22, 2015 - 06:15 PM.
Posted January 22, 2015 - 06:45 PM
It's going to be more abrupt than a WR, but shouldn't be too bad unless you've geared it lower.  That tends to exaggerate it.  The early EFI bikes were a lot worse than any carbed YZF I ever rode.
  • Navaho6
Posted January 23, 2015 - 12:53 AM
I did gear it down but that's not my main complaint.  The problem is the sudden, non-linear, light-switch-like spike in rpm immediately above idle. It was the first thing I noticed different about the YZ after coming off my WR.
I hate first gear in the YZ but if I could resolve this low rpm issue, it would be a lot easier to live with in the woods.
Are there any other differences between the YZ and WR other than fueling that contribute to this abrupt engine characteristic  (cams? spark?)
I'm going to check the pilot jet tomorrow.  If that doesn't work, I may order a G2 throttle tamer.  Maybe this Summer I'll split her open and drop in a WR tranny.
  • mdsharon
Posted January 23, 2015 - 07:09 AM
Rekulse, rekluse, rekluse, best mod for woods period!
  • DunmireD001
Posted January 25, 2015 - 07:47 PM
You could change the gearing and go down a few teeth on the rear sprocket, but then you will run into issues of too much speed.
My bike has the same problem. I just wanna downgrade to a 250 2 stroke
  • Navaho6
Posted February 02, 2015 - 06:47 PM
A friend suggested using a WR450 exhaust cam.  Might give it a try.
