2009 YZ450 won't stay running after it warms up
38 replies to this topic
  • pastranafan5
Posted January 19, 2015 - 08:56 AM
I just bought this bike and it starts and runs fine when it is cold, but after it warms up it won't stay running. It starts right up, but either dies right away or after several seconds. Does anybody have any thoughts on this?
  • x_JT_x
Posted January 19, 2015 - 10:42 AM
Is it acting like its starving for fuel? Or like its got a problem in the Engine?
  • Treeyz450
Posted January 19, 2015 - 04:27 PM
It could possibly be the stator. I just read a thread about this on the same year. The owner even bought an aftermarket stator, but after a lot of troubleshooting, he found that it was putting out a little too much, so he put an OEM one in and it ran fine.
Hope this helps
  • pastranafan5
Posted January 20, 2015 - 11:07 AM
I don't know if it's starving for fuel. It will be running fine and seem to die for now reason. I found out the pilot jet is a 52 and 45 is stock. Could that cause it? I hope it's not the stator. I hate electrical problems.
  • Treeyz450
Posted January 20, 2015 - 11:16 AM
Does it die like you hit the kill switch, or does it just shut down without the engine slowing down, like if it was locking up?
Also, is it ever physically hard to kick?
  • pastranafan5
Posted January 21, 2015 - 11:33 AM
Like the kill switch, but instantly. It's never hard to kick, and always starts easy.
  • torkd14
Posted January 21, 2015 - 11:43 AM
My '06 started doing that after putting a LEXX muffler on. The pipe was to restrictive with the spark arrester in and would cause the bike to die. You can either re-jet or in my case i just pulled the arrester out. I think you just have to do some jetting but im sure Greyracer will chime in with the proper fix.
  • Treeyz450
Posted January 21, 2015 - 01:47 PM
Ok, the only reason I asked is because my 08 450 used to just die, then it would be physically hard to kick, but when I got it to turn over, it was fine again. Then it would start and run for a little bit, then do it again. Come to find out, it was my main rod bearing.
  • Dexter42
Posted January 21, 2015 - 01:59 PM
I too would lean towards the stator or bad connection/ ground somewhere. Remove the tank and seat and just make sure all connections/ grounds are connected properly, no water in the sparkplug pocket, and if you have a multimeter it's really not that bad to check the stator. The manual will give you ohms reading it should be putting out and you tube will make it easy to identify what your trying to accomplish. You get a manual?
  • Treeyz450
Posted January 21, 2015 - 03:31 PM
+1...........like he said, check with a meter, then if they are reading right, get some electric contact cleaner, and clean all connections, and put a little dielectric grease on the connectors, then at least you know you have good connections.
  • jrice2012
Posted January 22, 2015 - 09:37 AM
By any chance did you buy this from a guy in Mississippi? My friend just sold his with it having this problem.
  • pastranafan5
Posted January 27, 2015 - 10:26 AM
Yes I did. I'm figuring that's why I got a good deal on it, lol.
  • pastranafan5
Posted January 27, 2015 - 10:29 AM
I have a manual. I'm gonna try that and see what happens. So y'all don't think the pilot jet being a 52 instead of a 45 would cause it? Or maybe bad orings inside the carb?
  • Treeyz450
Posted January 27, 2015 - 10:38 AM
I think if it is a problem with the pilot jet, it would have problems from the get go not just when it warms up. It would be a problem the whole time. I would definitely take the carb apart, clean it, and check based on your Elevation and make sure the right Jets are in it. do you have to use the choke to get it started? Do you have to leave the choke on or off to keep it running?
  • pastranafan5
Posted January 27, 2015 - 10:49 AM
I've cleaned it and put a 45 pilot jet in it and it seemed to be fine, except for running a little rough, but it was cold outside so I was gonna wait till it warmed up to see if it changes. I only have to use the choke when the engine is cold. Once it warms up it starts and runs without it. Would the stator not cause problems when it's cold also?
  • jrice2012
Posted January 27, 2015 - 11:25 AM
Definitely know that bike.. If it's a white one. Buy it from a guy in Southaven?
Posted January 27, 2015 - 11:47 AM
The stator can cause trouble only when hot, if the failure is of the right nature.  It can be a matter of the resistance increasing with temperature, which is a normal phenomena that might put the values out of spec under certain conditions, but more likely a transient open connection that butts up against itself well enough to make good contact when cooler, but opens when the coil gets hot.  Test the stator while it's acting up, and also try rapping on the stator cover with a wood hammer handle, etc., to see if that makes the meter bounce around.
  • pastranafan5
Posted January 27, 2015 - 01:50 PM
Yes
  • pastranafan5
Posted January 27, 2015 - 01:53 PM
I'll try that. If that's the problem though, why would it start right back up? Wouldn't it not start until it cools off?
  • jrice2012
Yes
I was thinking about buying it. That bike has a brand new head And valve train. If I'm not mistaken a new top and bottom too. Are you in MS? I'm in Oxford. If you get it right we should ride!
  • 5 replies
  • On January 15, 2017
  • 10 replies
  • 0 replies
