Yfz450
5 replies to this topic
  • Flatheaddad
Posted January 17, 2015 - 10:00 PM
I just bought a 2006 yfz450. It's my first thumper and the exhaust pipe get extremely hot. I think it's not normal? Any suggestions will be appreciated thanks
  • el caballo
Posted January 18, 2015 - 10:58 AM
I've read somewhere that that's suppose to be a sign of a carb issue. To rich or lean I don't remember but use the search bar and check the carb/jetting section. My 2001 runs very strong and never gets red hot.
Posted January 18, 2015 - 11:33 AM
The exhaust does normally get extremely hot.  A normal, healthy YZF will in fact get hot enough at an idle to be able to see a pronounced red glow if viewed in low light, such as in a garage at night. (about 800 degrees)
  • Yz450f1
Posted January 18, 2015 - 11:36 AM
They all glow red I have a 2012 when I first noticed that I was scared and I did a lot of research everything is okay I can't ride mine was shorts or Burns my leg
  • timhee
The yfz's do run a little hotter than most bikes, or at least, you can see it more (maybe the header is thinner?) But all yfz's I've eve been around do that. They are always the first to start glowing on a night ride. Most new 4 strokes do it, my ltr is the same way
  • Flatheaddad
Posted January 18, 2015 - 01:58 PM
Thanks everyone for the help
