WR450 No Spark
3 replies to this topic
  • he man
Posted January 16, 2015 - 06:22 PM
I tested my igniton  coil and the primary coil reads 00.4 ohms the limit in the book calls for .08 ohms, so this is quite a ways above.
Im not sure if this would cause a no spark situation or not ( im assuming it does since its the primary coil?). The secondary coil is within spec.
I checked for loose wires and even removed my ignition switch ( I previously mixed up the switches for the ignition and kill, but I don't think this does anything since it was the button that changed and not any wiring).
Any ideas before I try another coil? Im guessing the only way to is to buy one to find out if it solves the issue?
  • GuyGraham
Posted January 17, 2015 - 03:02 AM
More likely error in your meter
at very low resistance values, you need a real good quality meter to measure accurately
I fthe coil had failed, it would should open circuit (infinity)
0.4ohms is fine
The coil has not failed - your problem is elsewhere
  • stevethe
Posted January 17, 2015 - 09:44 AM
You might also check for your spark at night. Sometimes it's very hard to see it in the day.
  • he man
Posted January 17, 2015 - 11:03 AM
youre right, I forgot to factor in the resistance of the multimeter.
I traced back the harness, turns out I plugged the wrong wire into the kickstand switch so I guess that was causing a no spark signal.
All fixed now!
Thanks again guys!
