Wr250 oil tank on a wr459
9 replies to this topic
  • Uknowme53
Posted January 15, 2015 - 09:41 PM
Ok I'm new here and yes I did do a search but was Unable to find anywhere where someone has added the external oil tank from the wr250f onto a wr450f for the added oil. In my mind more oil = cooler oil. Cooler oil = longer oil Life and better protection agency wear on internal engine components. Any and all input would be appreciated. Ow Ya I have a 2007 wr450f ImageUploadedByThumper Talk1421386877.785939.jpg
Edited by Uknowme53, January 15, 2015 - 10:01 PM.
  • DunmireD001
Posted January 15, 2015 - 10:27 PM
Never heard of anyone doing it, but I can see where it would be a nice mod. I know there are also oil cooler kits that send the oil through a little intercooler/ radiator that mounts to your stock radiator to keep the oil cool as well.
  • Uknowme53
Posted January 15, 2015 - 11:59 PM
I could not find any for the 2007. If you know where I could find one please link it. I live in So. Cal and ride 50/50 street dirt and want to make sure the bike stays cool if I go down the freeway on a hot day.
I have no idea why Yamaha would give the wr250 2.5L of oil and only 1.5L in the wr450.
  • flyandride
Posted January 16, 2015 - 06:48 AM
Don't worry about overheating your bike on the freeway, it's the slow trail or traffic riding that heats up a bike.  I had a temperature gauge on my bike, at highway speeds it would level out at 145 even on a hot day.  A 4000 ft climb on a jeep trail would heat it up to 245.
  • stevethe
Posted January 16, 2015 - 08:40 AM
I don't think it's worth it and not necessary on a near stock bike. I know someone that went through a lot of trouble and put a oil cooler on a very hot very high HP road racing YZ450. I run my supermoto in the summer and there aren't any issues. Just change the oil frequently enough.
  • Uknowme53
Posted January 16, 2015 - 09:11 AM
My biggest concern is when I'm running down the freeway at 75 mile an hour for an extended amount of time. I just worry that only one and a half quarts of oil it's enough to lubricate the motor properly during sustained high rpm's I plan on putting the 15T front sprocket on any other suggestions? Or should I go with a 14T?
  • stevethe
Posted January 16, 2015 - 10:07 AM
The bike holds one quart and lubricates well. They are very oil tight and don't seem to use any oil. If you put more than a quart in it will spew out. The only issue is it needs to be changed fairly often.
You can try a 15 tooth it won't hurt.
  • Uknowme53
Posted January 16, 2015 - 01:18 PM
you don't think the 15 will be to much when I go off-road?
  • stevethe
Posted January 16, 2015 - 01:39 PM
Well there is off road and then there is nasty off road.
Probably be fine on normal stuff.
  • Uknowme53
Posted January 16, 2015 - 02:21 PM
Ya I try not to get into any nasty off-road I'm not a great rider just got back on a dirtbike after 3 years of not ridding.
