Yz450
8 replies to this topic
  • SILVANNAH
Posted January 14, 2015 - 03:58 AM
I have a yz450 dirt bike. I just recently tore the bike down to change the bearing and crank shaft. After assembling the motor I tried to start and everything was fine. Idle and all. When I shift to takeoff u can feel that it is in gear. Only problem was bike didn't want to move. I tried all gears and everything shifts right but will not move. Any suggestions.
Posted January 14, 2015 - 07:34 AM
Sounds like the clutch.  Start by making sure you have 3mm free cable travel at the clutch lever.
  • SILVANNAH
Posted January 14, 2015 - 01:04 PM
Gonna take a look a the clutch today.
  • SILVANNAH
Posted January 15, 2015 - 12:48 AM
Anymore suggestions.
  • Goforaride
Posted January 15, 2015 - 05:46 AM
Yep. Split the case again. Been there done that!
  • SILVANNAH
Posted January 15, 2015 - 02:08 PM
split the case but what do I look for. Forgot to mention, when on gear and high rev bike tends to move slowly.
  • Goforaride
Posted January 15, 2015 - 02:51 PM
It really sounds like a clutch issue. Maybe your mising a disk. Did you actually pull the clutch apart or did you just check the free play as ?suggested before
  • SILVANNAH
Posted January 15, 2015 - 05:38 PM
Just checked on the clutch and I installed it wrong. Two of the clutch were together and two disk were together. So I reset it. Now gonna put everything back. I'll post an update. Thanks for help.
  • SILVANNAH
Posted January 15, 2015 - 07:51 PM
Bike is running nice clean and fast. Thanks guys.
  • 10 replies
  • On January 15, 2017
