Yz450f must do mods for the trails.
16 replies to this topic
  • Johnnyv04 yz450f
Posted January 04, 2015 - 10:09 PM
I just bought my 04 yz 450f. I've gone through most of the previous discussions on TT but have a few questions...
I want my bike setup up for trails, I plan on changing the chain and sprocket. does 13/51 sound good? Is there a recommended brand for woods?
From what I have read a heavier flywheel is a must for the woods, can I add the weight to the stock one, or will that cause me problems? If I can add the weight should I get 10oz or 13oz?
Do I need a bigger aftermarket water pump?
The rekluse set up is so expensive, is that a must???
Thanks for your help, I'm knew to TT so I hope I put this in the right spot
  • KcDavis
Posted January 04, 2015 - 10:33 PM
The only "must" is suspension.  From there, everything is all preference.
  • woods-rider
Posted January 04, 2015 - 10:37 PM
The '04 is a horrible woods choice, it's got a 4 speed gear box. I had one and tried to make it woods friendly, it was terrible. You could either gear it for technical riding which would give you a top speed of around 35-40, or gear it for more open terrain which put first gear around 20 mph.
  • Hoosier-Daddy
Posted January 05, 2015 - 12:31 AM
I have an 09. I went with heavier flywheel and love it. Suspension and gearing also helped me.
  • jakePawoodsrider
Posted January 06, 2015 - 08:00 AM
I had an 03 terrible bike it overheated like no other
  • cadesdad
Posted January 07, 2015 - 09:24 AM
I had a 03 yz 450f, it was a monster for trail riding, but I loved it. I geared mine a little taller than stock to tame the hit, and added a flywheel weight. It really smoothed it out and made it much easier to ride, however as was mentioned before, it had a very tall 1st gear. I think the ultimate would be to add a wr 5 speed and a flywheel weight. Of course the right springs and suspension first and foremost.
  • Johnnyv04 yz450f
Posted January 07, 2015 - 05:31 PM
What front and rear sprocket size did you use for your 03??
  • YamaLink
Posted January 08, 2015 - 07:32 AM
How much do you weigh?
  • cadesdad
Posted January 08, 2015 - 04:36 PM
  Front sprocket was 14 (stock I think) and the rear was 47, only 1 tooth higher than stock.  I originally tried 14/50 to use for trail riding, which worked great for low speed but the hit was brutal for me (older wuss) on an already brutal machine.  I tried the 47 rear first and it helped a bunch, then I installed the flywheel weight and together it was awesome!  The 03-05 4 speeds were more like having 1st gear removed instead 5th gear compared to a normal 5 speed.
  • Johnnyv04 yz450f
Posted January 08, 2015 - 09:20 PM
I'm a fairly solid guy at about a buck85.
  • mdsharon
Posted January 09, 2015 - 03:35 PM
Yes rekluse is a must best money you can spend!
  • Goforaride
Posted January 09, 2015 - 04:18 PM
G2 throttle tube.
  • Mumm32
Posted February 13, 2015 - 12:31 PM
  • Ajflegel
Posted June 02, 2015 - 06:33 PM
What size flywheel weight?
  • cadesdad
Posted June 02, 2015 - 06:57 PM
I went with the heaviest weight that Steahly made for the 03 yz450, I think it was a 13 Oz. but I can't remember for sure. It made a huge improvement for trail riding.
  • 03yzf450-kuke
Posted June 03, 2015 - 02:35 AM
I still own an 03 and love it in the trails. I ride really tight trails so mines geared at 12 49 and it works great on tight or open trails
  • 03yzf450-kuke
Posted June 03, 2015 - 02:44 AM
Ive also only overheated mine once when i was stuck in the mud. So unless the trails your on are tighter than mine which i highly doubt you should be good to go
  • On January 15, 2017
  • Hot  30 replies
  • Hot  50 replies
