Hour meter?
13 replies to this topic
  • rojapar
Posted December 29, 2014 - 05:54 PM
Does anyone have any pics of where they are mounting an hour meter on a 2014-2015 450?  Also, what is the best kind to get?
  • TrackSnail
Posted December 29, 2014 - 11:48 PM
I just use my gytr tuner to track hours
  • rojapar
Posted January 03, 2015 - 07:12 AM
finally picked the bike up.  looks like id have to start taking the side panels off, the tank, etc to get an hour meter hooked up.
i didnt know the tuner tracked the hours.  so do you just plug it in and it tells you how many hours are on the bike?
  • jmack
Posted January 07, 2015 - 08:01 AM
I bought a hour meter for my 14 450 and gave up on placement. I just use the tuner. It's super easy. P
  • Motocucca
Posted March 01, 2015 - 02:42 PM
I mounted mine under the seat.. Made a small aluminum bracket and safety wired it to the piece.. There is a small hole next to the tank bolt where you can connect bolt it to.. Works great no issues,,
  • GHILL28
Posted March 01, 2015 - 06:09 PM
I put mine on the front of the headtube behind the number plate.  Just turn the bars and you can see it between the fork tube and the number plate.  Stays relatively clean that way too.
  • boegey
Posted March 02, 2015 - 12:28 AM
I mounted mine at the top of the frame just below where you plug the tuner into easy to see there doesn't get damaged and easy to hide the wires just run it along with the other wiringImageUploadedByThumper Talk1425284892.906933.jpg
Sorry havnt washed my bike yet after the weekend lol
  • jmooney70
Posted March 02, 2015 - 03:49 PM
I use the Works Connection Tach / Hour Meter and the Works Connection Mounting Bracket.
It looks like it was made to fit here.
Tach / Hour Meter
http://worksconnecti...return=--YZ450F
Mounting Bracket
  • mikea890
Posted March 03, 2015 - 06:57 AM
i ordered the works connection hour meter and bracket you just take your gas tank bolt out and mounts right to that easy!
  • bura76
Posted March 06, 2015 - 03:06 AM
jmooney70
But you have to remove it every time you change the air filter ???
  • Motocucca
Posted March 06, 2015 - 03:31 AM
jmooney70
That's why I mounted mine under the seat....ImageUploadedByThumper Talk1425641476.811684.jpg
  • Motocucca
Posted March 06, 2015 - 09:35 AM
Here is a better pic how I mounted it.. Easy to read, stays clean and doesn't move..
  • jmooney70
Posted March 06, 2015 - 12:50 PM
jmooney70
Two extra screws and I don't mind.
  • Tiago
Posted March 10, 2015 - 07:48 AM
More here: http://www.thumperta...6795-my-15-bike
  • Hot  36 replies
  • 10 replies
  • 5 replies
  • Hot  38 replies
  • Hot  50 replies
