Bike won't idle and dies
3 replies to this topic
  • Yzrider1023
Posted December 29, 2014 - 02:31 PM
So I just cleaned my carburetor on my yz450f 2006 and I also adjusted the needle clip down one position because it was running lean and after I put it back together it was running fine even better than before but today I started it up and it wouldn't idle and then it would backfire and then it stopped and it also seemed a bit louder than before so then I tryed to start it again and it wouldn't start unless I pumped the throttle 2 times then it just did the same thing
What I want to know is how can I fix this and what is wrong with this thing
It's also been really cold lately so could that be a factor?
  • Wild Alaskan
Posted December 29, 2014 - 02:58 PM
fourstrokes get really sensitive in the cold, run it on choke a bit longer, or adjust the idle mixture screw.
  • Yzrider1023
Posted December 29, 2014 - 04:56 PM
I've tried that it won't even idle with choke on
  • Wild Alaskan
Posted December 29, 2014 - 05:36 PM
might need to clean the carb again then, focusing on the idle circut.
