Project 2003 WR450 from the grave
13 replies to this topic
  • dweaver76
Posted December 29, 2014 - 11:44 AM
Hi guys. Been a while since I've posted here.
So my wife got me a project bike while I was in Afghanistan this last summer.
A non running plated 03 WR450. Now I've worked and sold many just for the love of the WR and tinkering but this one I plan to be my keeper.
Previous owner did an awful hack job of scrap yard parts and wires to get it plated and its more of a mess than I'm interested in.
Want to make this a light, cheap trail bike.
In eliminating the clusterf$#k of wiring the PO put on I'm looking at gutting all the wiring and E-start for simplicity and cost.
In short what wiring is minimum needed to get spark and keep the bike running?
Cleaning the carb today and will be doing a valve adjust and compression check this week to hopefully fire it up this weekend.
After that comes the ton of bearings and for seals that need repair.
Thanks as always.
  • dweaver76
Posted December 30, 2014 - 05:58 PM
OK last part was obviously to wordy. Checking valves before a compression check. Within spec but the cams don't line up at TDC. Picture attached.
That look like a mod or possibly after market cams?
  • dweaver76
Posted December 30, 2014 - 06:00 PM
Lobes at TDC
  • dweaver76
Posted December 30, 2014 - 06:40 PM
Disregard that compression check. Forgot about auto decomp on these.
  • flyandride
Posted December 30, 2014 - 08:16 PM
If that's at TDC then the cam timing is off.  Here's what it should look like.  This is an 09.
  • dweaver76
Posted December 30, 2014 - 09:23 PM
That's what I though just wasn't sure if timing is changed in case its a Hotcam.
Next up...what does this black electronic part do? Wire was cut by previous owner.
  • dweaver76
Posted December 30, 2014 - 09:24 PM
Only about $500 for the bike....starting to lean towards parting it out.
  • still2smokin
Posted December 30, 2014 - 09:50 PM
Could be wrong but believe that is the neutral safety switch, probably cut so will start with the button in gear w/o clutch being pulled in.
Also could be wrong , Some achieve the same function by fusing the clutch switch wires together . One or both affect the ignition
timing a bit .
Download a manual in the links at the top of the WR forum and check out the wiring diagram to be sure .
Why would you even think about parting a plated WR in CA , that's just crazy talk .
Where in CA are you ?
  • dweaver76
Posted December 30, 2014 - 10:05 PM
A bit north of Sac. Have the manual and all wiring diagrams I've found so far are for lights or are generic.
Looking for minimum wiring that will get me spark.
  • still2smokin
Posted December 30, 2014 - 10:34 PM
There plenty of people on this forum more experienced than me but , if your wiring diagram is generic in any way you do not have the
the Yamaha Factory manual . It is very clear , wire colors and all . I had a wiring issue getting  only intermittent spark for a while and the factory manual
has procedures on testing all of the electrical components except the CDI . In the end I had a faulty connection to the coil/sparkplug
connector at the wiring harness .  Not saying that is your problem , just start eliminating possible problems .
Is your battery good ?
Best way to check actual spark is with another spark plug, leave original in the head ( or could have a fire , seen it before ) and extra plug attached
to coil and ground to engine while kicking .
Edited by still2smokin, December 30, 2014 - 10:35 PM.
  • dweaver76
Posted December 30, 2014 - 10:39 PM
Battery was dead when I got it and starter is now removed. Starter bolts were loose and I just eliminated it probably for good.
Think you reposted my same picture in your example picture.
  • flyandride
Posted December 31, 2014 - 01:48 PM
That's the neutral switch.  Mine has Hotcams also.
  • dweaver76
Posted December 31, 2014 - 02:01 PM
flyandride are your cams offset at tdc like mine are in the picture I posted?
  • Wristrockit
Posted January 02, 2015 - 06:10 AM
He did.
