2005 YZ450F hard starting except when warm
6 replies to this topic
  • dattorob
Posted December 28, 2014 - 07:04 PM
HI there,
I have recently had my engine rebuilt with new valves etc.
Unless the bike is warm it can be quite hard to start as in more
than 5 kicks.
I have googled and search TT and have found a few things to check
such as :
·         Try iridium plug It is just CR8IX
·         Check boot is sealing ok
·         Check pilot jet??
Also found one suggestion about changing starter jet (mine is 72) and
also another about removing neutral switch. Has anyone tried these
things?
cheers
Robert
:aussy:  :goofy:
Posted December 29, 2014 - 07:32 AM
Is this unusual for the bike?
If the pilot jet were partly blocked, it would also run poorly when warm (bogging, stumbling, etc.).  On the other hand, it's fairly common to have one block up if it sits for a while in warm weather.  Try this, and be sure to check the starter jet as well:
http://www.thumperta...o/#entry6879695
  • dattorob
Posted December 29, 2014 - 08:51 PM
Thanks Gray, you're scholar and a gentlemen :) .
i guess its never been an easy starter, i think partly could be i have non-OEM boot clamp between boot and carb and
may also be i got bit of water up one of overflow pipes when washing it.
What should i do with starter jet? i guess check its clean etc.
Also being a big bore requires extra bit of oomph to kick it over it think.
The only other thing i can think is my process/method for strating it
is slightly flawed as in i don't blip the throttle to prime it, so i will add that in.
cheers
Robert  :ride:
  • Wiz636
Posted January 03, 2015 - 12:55 PM
Years ago I quit trying to clean jets and instead simply replace them.
On my '08 when cold I would find the compression stroke with the kickstarter, give it two full twists of the throttle, then kick it over and it usually started right up.
  • dattorob
Posted January 03, 2015 - 08:07 PM
I would have thought cleaning with carb cleaner and using compressed would do the same trick.
But yeh i do need to alter my starting technique i agree. cheers
Posted January 04, 2015 - 07:35 AM
The pilot jet is too small for that to work most of the time.  Read:
  • dattorob
Posted January 04, 2015 - 02:17 PM
Ok wow that is small. You have a point. Cheers
  • Hot  47 replies
  • 0 replies
  • 10 replies
  • Hot  50 replies
