WR450F Query
6 replies to this topic
  • n000b3rt
Posted December 25, 2014 - 01:37 AM
Since putting an FMF Powercore muffler on the bike, it has become hard to start and backfires slightly. Is this normal or do I need to change the powertune to correct it? If so, what is recommended to change it to?
  • AtomicGeo
Posted December 25, 2014 - 05:49 AM
Couple of questions:
1.) Did you remove the air intake snorkle yet?
2.) Did you install the race ECU module?
  • guru
Posted December 25, 2014 - 09:46 AM
Assuming it is a FI (2012 and up) model, did you swap out the ECU and is your idle at 2000+/- ? Search for CO settings or starting problems/issues. Many here bumped up CO settings. I'm at 10 with the powercore and that fixed the extremely annoying starting situation. Good luck.
  • n000b3rt
Posted December 25, 2014 - 10:58 AM
1) No we didn't remove the snorkel
2) Are they parts of the off road kit for the WRs?
Thank you heaps, I'll keep you's posted :) thank you to you both
Edited by n000b3rt, December 25, 2014 - 10:58 AM.
  • AtomicGeo
Posted December 25, 2014 - 07:44 PM
Remove the snorkle.  Then if you have the programmable ECU, have it programmed or buyt the power tuner to program it.  It's going to be extremely lean otherwise.
  • Juman5
Posted December 27, 2014 - 04:57 PM
It will still be lean at idle unless you get your hands on a FI diagnostic Tool and change the A/F mix.
  • n000b3rt
Posted December 27, 2014 - 06:12 PM
I think we can do that with the power tune, we're addressing it as we speak, we'll keep you guys posted :D
