crank question
3 replies to this topic
  • Adam842
Posted December 23, 2014 - 10:20 AM
Right now I am rebuilding a yz400f that i bought off my buddy for $150. He sold it because he was finding metal shavings in his oil. when i took the top end off I saw the crank has a gouge on the weight just on one side from the rod hitting it at BDC, My question is how could the rod rub the weight if the piston still fits tight in the cylinder. Could it be from last year when he installed a new piston could he of torqued the head down more to one side letting the rod hit the counter weights or what. I don't know if this helps but the top of the piston has tons of carbon and fouled lots of plugs after the piston had about 50hrs on it and the crank stills turns real easily. Any input is appreciated,
  • GEOF
Posted December 24, 2014 - 01:19 AM
Can you post a pic?
Posted December 25, 2014 - 07:56 AM
The piston doesn't center the rod, the rod side shims do.  Side clearance of the rod on the crank pin shouldn't exceed .020"
  • Adam842
Posted December 25, 2014 - 11:01 AM
Can you post a pic?
ill try to post one tommorow
  • Hot  38 replies
  • Hot  50 replies
  • Hot  47 replies
  • Hot  30 replies
  • 10 replies
