best battery?
4 replies to this topic
  • adam500
Posted December 14, 2014 - 04:17 PM
My 03 needs a new battery.
Should I go gel or liithium?
Is there a favorite brand aroud here?
Best cranking amps? 100+.
Whats everyone running?
  • stevethe
Posted December 14, 2014 - 04:33 PM
If you want lightweight get a Shorai.
  • RMK800
Posted December 14, 2014 - 05:17 PM
+1
https://www.rockymou...um-Iron-Battery
  • flyandride
Posted December 14, 2014 - 09:02 PM
Lithium will save you 2-3 lbs.   If you decide to go that way, wire a plug into it so you can test the battery voltage easily without taking off the seat.  Lithium batteries are ruined if they discharge below 8 volts.  I learned that the hard way.  I ordered a little volt meter to wire in so when the power is turned on I can see the voltage.
Edited by flyandride, December 14, 2014 - 09:07 PM.
  • woods-rider
Posted December 14, 2014 - 10:44 PM
Or just get an EarthX, they have circuitry built in to prevent over discharging so you can't hurt the battery if you accidentally leave a light or accessory on when you are done riding.
