Spring Help!!! (Wide Load!)
5 replies to this topic
  • sideoute
Posted February 05, 2004 - 12:05 PM
Can someone help locate a company/website with heavy duty springs for my BRP??? I'm thinking a 12.5kg or 13.0kg spring.
Thanks,
Brett
  • Dutch
Posted February 05, 2004 - 02:22 PM
http://www.racetech....t.asp?showPage=
  • sideoute
Posted February 06, 2004 - 01:34 AM
Thanks for the web-site. It appears they only have them up to 12.0. Nice website.
Brett
  • mash
Posted February 14, 2004 - 10:38 PM
Find a spring maker, I had my rear modified and new front springs made for a fraction of the cost of motorcycle "brand" name springs. A good spring making company should be able to make you some heavy duty units. :)
  • pantaz
Posted February 14, 2004 - 10:59 PM
I'm 295 lbs and I'm running Eibach 11.0 kg/mm & 0.45 kg/mm. It's as close to perfect as I could expect. I went to ESP (see below), and this is what they recommended.
Exceptional Suspension Products Inc.
6642 Foothill Blvd
Tujunga, CA 91042
(818) 951-9144
  • mash
Posted February 15, 2004 - 11:00 PM
This is the same as my setup, except i had half a coil removed from the rear spring to achieve 11kg/mm. Works well, I also revalved my front compression stack. They are overdamped stock and removing 4 of the 12 shims has made a world of difference.
  • Hot  29 replies
Honda XR650L 2017
  • 0 reviews
  • 9 replies
  • Hot  35 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
