oil leak, need help
2 replies to this topic
  • yz45life
Posted December 11, 2014 - 07:15 PM
So I just changed the oil seals for the water pump and I put the crank case back on with a new gasket. It appears to be leaking oil right along the seam of the case on the very bottom, I can't tell if it is dripping down from somewhere else. Anyways if anyone has had the same problem let me know, I really can't figure it out.
Edited by yz45life, December 11, 2014 - 08:46 PM.
  • sckrocodile
Posted December 12, 2014 - 05:29 AM
More than likely you improperly tightened the bolts on the cover you removed.. refer to you owners manual for procedure and torque.
Posted December 12, 2014 - 07:28 AM
It's probably more likely that a piece of the old gasket was left stuck on one of the two surfaces.  Very common mistake, and certain to cause a leak.
  • On January 15, 2017
  • Hot  47 replies
  • Hot  113 replies
  • 0 replies
