CHANGING OIL!!!!!!
2 replies to this topic
  • yamie_rider
Posted February 01, 2002 - 05:44 PM
When you drain the oil from the frame , how much oil stays in the crank case????
  • sirthumpalot
Posted February 01, 2002 - 06:17 PM
If the motor has been run recently then there typically isn't much in the crank case at all. I don't have a measurement, but it seems to be a fraction of what is in the frame.
  • Boit
Posted February 01, 2002 - 09:34 PM
Yamie; this is a dry sump engine which means that the oil reservoir is the frame tank. If you look at the line from the bottom of the frame tank and follow it to where it enters the crankcase, you can see that the oil is then picked up by the primary pump and fed thru the filter on to the crankshaft bearings and cylinder head where it gravity/overflows to the secondary pump on the left side and then back to the frame tank. Once then engine is shutdown, the bulk of the oil remains in the frame tank. I've never measured how much oil drains from the crankcase, but I would estimate it at ~3 ounces. It's not much at all.
  • Hot  28 replies
  • Hot  47 replies
Motocross
  • Hot  491 replies
