Green Ooze
6 replies to this topic
  • yamahakid426
Posted December 10, 2014 - 08:25 PM
Ive had this bike for a couple weeks now and notice that after every ride when i park it in the garage some green colored foamy ooze leaks out of this tube. I dont exactly know what it is and was hoping if anybody could tell me. Thanks
  • dirtbeater
Posted December 10, 2014 - 08:29 PM
I believe that's the crank case breather tube. It comes from the valve cover. Looks like milky oil possibly. Check your oil level, color and your coolant level.
  • yamahakid426
Posted December 10, 2014 - 08:32 PM
I just bought this bike and i just replaced the oil with yamalube 20-50. but i havnt checked or replaced the collant. That will be on my list to do then
  • bigbird192
Posted December 10, 2014 - 08:53 PM
That tube should not drip anything but oil. it looks like you have coolant in your oil. I would drop the oil and see if it is milky or otherwise discolored. If it is, you likely have a head gasket leak. Also, when you refill it, i would suggest using a lighter oil, such as Yamalube 10-50. The 20 weight you are using is pretty thick, especially for the cold climate.
  • gscx
Posted December 10, 2014 - 08:55 PM
If you ride when it is wet then thus will happen. It's no big deal. If your coolant level isn't dropping that is...
  • yamahakid426
Posted December 10, 2014 - 09:02 PM
alright i will flush the coolant and refill with lighter oil and see if that works
  • yamahakid426
Posted December 10, 2014 - 09:07 PM
after i changed the oil i did notice that it was considerably less than before so maybe going lighter will get rid of it
  • 10 replies
  • Hot  28 replies
  • Hot  50 replies
