yz450f timing mark
6 replies to this topic
  • Duane123
Posted December 09, 2014 - 03:08 AM
have a 2003 yz450f and I am currently putting it back together from a blown head gasket, I have the head on and I am now trying to get tdc by lining the line up with the engine cover and as it's about to line up it notches over and will not line up, as it gets to tdc it gets slightly tight then falls past its mark, has anybody had this trouble before, what can be done. Thanks
Posted December 09, 2014 - 07:43 AM
If you are rotating the engine with the starter, you'll never get it to stop in the right place.  Put a wrench on the crank and do it that way.  Asa you turn the engine with the spark plug in place, it compresses air in the cylinder.  That pressure will bleed past the rings if you give it a second, then the crank will stay at TDC.  Remember that the crank can turn 3-4 degrees either way and barely move the piston, so it's easy to rotate it off TDC as you work.
  • Duane123
Posted December 09, 2014 - 11:19 AM
Yeh mate i have been turning it over with a wrench on the crank, but I have the spark plug out, should I have it in
Posted December 09, 2014 - 12:42 PM
With no plug, there should be no tendency for it to roll over the top unless you have the cam lobes pointed down, which would be incorrect.
  • Duane123
Posted December 09, 2014 - 12:45 PM
Well I have no spark plug and no cams in, just the head on and when I crank it to tdc wig a wrench it pops past the tdc mark every time.
Posted December 09, 2014 - 06:35 PM
If you feel ANY resistance going over TDC without the plug in or the cams in place, something is wrong.
  • 72degrees
Posted December 10, 2014 - 03:19 AM
What grayracer said. Or is not so much resistance or a tendency to overshoot TDC. Is it possible the flywheel weight momentum keeps it moving? - I suppose not.  Have you also tested for TDC with a probe through the plug hole? I preferred to do it that way and turn the motor by having it in top gear and nudging the wheel round - not an option until the motor is back in naturally ;)
  • Hot  36 replies
  • Hot  113 replies
Motocross
  • Hot  491 replies
  • On January 15, 2017
