  • Instagram
Related Garage
Yamaha YZ400F (1999)
Owner: Thumpacular
Added on January 18, 2017
Related Reviews
Yamaha YZ450F 2004
Last review by 1trackmind
Yamaha YZ450F 2016
Last review by YZJeffro64
Yamaha YZ450F 2007
Last review by 24moto
Yamaha YZ450F 2011
Last review by Le_Racer
Yamaha YZ450F 2006
Last review by Yzrider1023
Skid plate recommendation
42 replies to this topic
  • waltersobchak
Posted January 23, 2015 - 01:17 PM
Agreed - Jon makes a great product, and he's a one of a kind dude. His skills and endurance on a bike are impressive.
Just got my SXS slide plate installed, pretty happy with the purchase.
  • Darvo and bigvaportrail like this
  • Like This
  • GHILL28
Posted January 23, 2015 - 02:51 PM
That thing could sure use some vent holes/oil drain holes and a bit more side protection.  I like the idea of it extending back to the linkage though.
  • waltersobchak
Posted January 23, 2015 - 03:15 PM
I don't know if it's just the angle of the pics or what, but this thing has more side protection than any other skid plate I've seen.
I'll probably take it off for oil changes, so not to worried about oil leaking onto it.
  • rojapar
Posted January 23, 2015 - 04:21 PM
i wouldnt get the gytr.  i finally just couldnt stand looking at it anymore and took it off and ordered a tm designs.  ill let you guys know how it is.
  • GHILL28
Posted January 24, 2015 - 09:32 AM
Look at the Cycra full-wrap plate coverage for comparison.
However, I'm not terribly thrilled with the cheap easily-rounded hardware on my Cycra skidplate at the moment either.  Going to occupy more time than I'd like to extract that damn thing.
  • drtrcr400
Posted January 25, 2015 - 08:42 AM
Did you have the aluminum or plastic GYTR skid plate? What did you not like about it?
  • Ron Roberts
Posted January 25, 2015 - 10:15 AM
I have a metal one and don't like it.  It is very thin and sticks out to much on the sides and doesnt wrap up very high to protect the engine sides.  It is also difficult to mount.
  • savagex
Posted January 28, 2015 - 09:38 PM
I have the Acerbis Skid plate on my 14.  A few complaints: 1. It pinches the over flow tube near the water pump. 2 Its easy to take off, but can be a pain to put back on. There is a rotating arm that fits behind the frame to hold it in place and sometimes that doesnt want to rotate.
  • Wiz636
Posted January 29, 2015 - 09:07 PM
Vent holes? Huh?
  • GHILL28
Posted January 29, 2015 - 09:17 PM
Yeah, on the front.  Keep air moving across the motor as much as possible.  Radiators are only part of the equation.
  • YzCas
Posted January 30, 2015 - 01:48 PM
I've got the wc mx plate it fits really well looks good don't notice any noise and is more than solid enough to take anything you could throw at it, smashed it over about 10 logs last time I was out and I can't see any damageattachicon.gifImageUploadedByThumper Talk1421474442.620903.jpgattachicon.gifImageUploadedByThumper Talk1421474488.512459.jpg
How much did that skid plate cost?
  • xXHaNsEnXx
Posted February 06, 2015 - 12:01 PM
is that the mx plate or full coverage plate?
  • savagex
Posted February 08, 2015 - 05:59 PM
I think it may be the Full coverage, not the MX.  This is what i purchased
I only ride MX so it will still work.
  • boegey
Posted February 09, 2015 - 12:37 AM
Pretty sure it was around 110 aud so it's probably heaps cheaper in America but it seems to work pretty well fits and looks really good
  • Mumm32
Posted February 13, 2015 - 08:14 AM
Unabiker!!! I have the rad guards, and skid plate!! Great fit, great look!!ImageUploadedByThumper Talk1423844046.899321.jpg
  • Goforaride
Posted February 13, 2015 - 04:14 PM
I have the same full coverage cycra. Those stupid hex bolts rounded out the first time I had to remove the plate for an oil change. My solution was to go to the local parts store and buy some bolts with a 10mm head. No more problems there. My only complaint is having to remove it to change oil and wash it. It holds mud a debri like no other. It has such good coverage that the only way to spray water below the frame rails is through the vent holes. If you don't remove it after every ride, you end up With a 1/4 inch layer of mud baked onto the bottom of the cases.
  • GHILL28
Posted February 14, 2015 - 07:29 AM
That's exactly what I have now.  SS M6 hex heads with a 10mm hex.  Works great.
Definitely gonna have to get some foam for the bottom of it at some point too.
  • Gink
Posted February 16, 2015 - 06:20 PM
No complaints about the gtyr skid plate. Bolted up to the bike no problems and came with foam.20150201_083414.jpg
Edited by Gink, February 16, 2015 - 06:26 PM.
  • bigvaportrail
Posted December 27, 2016 - 02:48 PM
2015 yz450. Just installed my skid plate last night and ditto on the comment listed above. Pinches crank breather almost completely. Had to cut the front bracket 1/4" and drill a hole on each side to zip tie the bracket in place to make it easier to install. The rear mounting screw is wrong diameter and I had to re-drill all the mounting holes in order to fit. I would spend the extra 20 bucks more and get another brand. Just sayin
  • CSAR FE
Posted December 27, 2016 - 02:50 PM
I've been using the Cycra Full Coverage skid plate and its worked really well. I like it because it allows the chassis to continue to flex, unlike the aluminum and steel models I've used on my other bikes in the past.
  • Hot  28 replies
  • Hot  38 replies
  • On January 15, 2017
  • Hot  47 replies
