2012+ WR450F Stronger starter motor?
64 replies to this topic
  • WRF-Rowdy
Posted September 15, 2015 - 03:13 AM
#61
The Yamaha branded FI diagnostic tool was $114.00 [depends on current Euro exchange rate] from the company in the Netherlands referenced above and shipping took less than a week. The Chinese tool is listed at about $230. So the Yamaha tool is much more affordable.
Personally, I'd rather kill myself before I shell out $114 to get 12V to the CO tool's terminals. You need that tool only once, to set CO to -20.
  • drdanbozeman
Posted September 15, 2015 - 06:18 AM
#62
I followed the link you provided in order to purchase the tool. If a tool is not available locally, then buying the tool seems to be a reasonable option; selling it online after a good CO setting is accomplished would avoid the downside of offing oneself.
With a minus setting my bike would not start reliably; with a setting of +12 it starts first push of the button hot or cold. I've got a Megabomb header and Q4 pipe.
  • WRF-Rowdy
Posted September 15, 2015 - 06:56 AM
#63
Truly amazing! :jawdrop:
Mine won't fire up nicely with positive numbers, to the point of only firing up on third attempt w/o gear when hot wiht CO 6 or higher!
  • tomerb
Posted September 16, 2015 - 08:39 PM
#64
Does anyone know what the real AF ratio is at idle? Do people that have rest there CO with the Yamaha tool still have a slight decel pop during compression braking.
  • WRF-Rowdy
Posted September 17, 2015 - 10:48 PM
#65
my WR450F'12 idles at stochimoetric A/F when CO ist set to -25,
see http://www.thumperta...ic-vs-af-ratio/
But there are poeple on thumpertalk, whose bike won't start at negtive CO setting, hard to believe but YMMV :jawdrop:
My experience from my WR400F and WR450F'03 ist that one HAS to set the idle mixture to a value
that creates heavy popping on decel, if one wants to reliably e-start the bike in gear.
Mind you, the '03 Keihin ist supposed to have a decel. enrichment circuit.
I had checked mine, all seemed ok, still very noisy popping on road-racing deceleration.
And I had to pull to hot start lever on my '03 WR450F while e-starting in gear (hence idle must have been still too rich)
Edited by WRF-Rowdy, September 17, 2015 - 10:50 PM.
