New 2014 on the way! Couple questions
32 replies to this topic
  • rojapar
Posted December 06, 2014 - 04:57 AM
I really wanted to get a YZ250, but was at the dealers and they had the YZ450F for $1300.00 cheaper, so I couldnt refuse.
I had a couple questions...the dealer said they have the map adjustment tool and said I could bring it in and they would adjust it for free.  I was reading some reviews and found this map:
fuel
333
443
443
ignition
222
222
222
Should i have them go ahead and put this map on their before i leave the store, or should i ride it as is first.  Im going to keep the bike 100 percent stock as far as any performance mods go and it is going to be used as a play bike, riding trails, and some light duty motorcross play
Next question...at one time i was going to buy a yz125...it was a used 2006 model iirc.  i was reading reviews before i bought it and it said the shift stop bearings would would explode and end up all over the engine and ruin it.  the fix was to use a different roller set up off a 2007 model.  Being of limited mechanical skill, I passsed because I wasnt comfortable tearing into the engine.
Then i was reading the 2014 450 had bearings in the shift stop and they changed it for 2015.
So now I'm a little concerned that I need to put the updated shift stop in it.  Anyone have any ideas about that?
Thanks
  • YzCas
Posted December 06, 2014 - 05:25 AM
fuel
333
443
443
ignition
222
222
222
Thanks
Thats a good map I run it but on every plus on fuel I go negative on the timing one it's the best map I've tried it's an mxa map. It gives the bike power everywhere and I have a fmf power bomb header with a 4.1 core slipon. You can't go wrong with that map I personally would go negative one on timing every where you go up in timing that's what mxa a did. I just had the dealer do the shift stopper it cost me 90 for the part because they had the bike apart for putting in a rekluse core 3.0. I would just have the dealer do it why it's there see if he will call yamaha and work with you if not it's like a 200 dollar fix.
Edited by cas747, December 06, 2014 - 05:30 AM.
  • Dexter42
Posted December 06, 2014 - 07:42 AM
Since your going to be using this bike for mostly play and trails I wouldn't go with that map. Also your leaving it stock which really you shouldn't have to remap. If I where you I would take some of the aggressiveness out of it by adding some fuel and retarding the ignition down low some to help out on the trail riding and playing. The map you show seems like a more track related map. Also it seems like a lot of fuel for a stock bike. .02c
  • rojapar
Posted December 06, 2014 - 08:10 AM
thats crazy they would put a known defective part in the bike.  i mean, on the yz125 they knew it was a problem in 2006 and fixed it in 2007.  fast forward to 2014 and they put in the exact same part that is highly prone to failure.  i dont get it.
  • YzCas
Posted December 06, 2014 - 08:38 AM
. In know and Theye revised the part and wouldn't pay for it to be put in. I also have a 14 250f same problem and the water pump shaft yamaha made new revised parts but would not acknowledge a problem so I had to pay for both. I love yamaha's or I would have switched brands but there customer relations sucks.
Posted December 06, 2014 - 09:11 AM
They will pay for those that fail under warranty, just like they told you they would.  The '06 YZ450 had the same "problem".  For perspective, I replaced the one in my son's '06, but never my own, and after 350 hours, it hasn't broken.  I know of at least 3 other '06's with the same "defective" part that are still running the original ball bearing arm.
  • YzCas
Posted December 06, 2014 - 09:24 AM
My dealer told me yamaha did not put a code 90 recall code on it so it wouldn't be covered if the motors grenaded on both my bikes and I took my 250 in two weeks after I bought it. Theye simply weren't calling it a recall it was a customer decision upgrade.
  • rojapar
Posted December 06, 2014 - 11:41 AM
One other thing...I was looking for a kick stand.  What is the best brand to get for this bike?
Thanks again
  • YamaLink
Posted December 06, 2014 - 01:32 PM
For kick/sidestands most look at Pro Moto Billet or Trailtech, if applicable.
  • zeuszuki
Posted December 06, 2014 - 11:46 PM
It is also up to the dealer, my dealer has replaced EVERY '14 250f and 450f shift stopper for the bikes he sold at no cost to customer. Might pay to ask, the worst they will do is say no.
  • YzCas
Posted December 07, 2014 - 04:56 AM
Thanks again
I don't know what brand nane it is but it's great you put your bike on the platform then push down and it's secured both wheels off the ground. Check out Rocky Mountain ATv they have them.
  • writebrian
Posted December 10, 2014 - 09:19 PM
Thats a BIKE stand, not a KICK stand. It would be a bit bulky to carry on trail rides.
  • CZRoger
Posted December 11, 2014 - 08:58 AM
My '14 was lean when new with no mods. Fyi
Checked my shift stopper at 20hrs and it was fine. Changed it anyway as it was cheap insurance.
  • YzCas
Posted December 11, 2014 - 09:15 AM
. Ya I changed mine to with four hrs on it to be safe. I have a real good map for the bike if your interested I can post it for you it really made the bike respond well in all areas.
  • rojapar
was it lean enough to do any damage to the engine in the factory configuration?
if so, what kind of map did you use on your stock engine with no mods?
thanks
  • CZRoger
Posted December 11, 2014 - 09:21 AM
thanks
No damage, not that lean. Typical decel pop on occasion.
Can't help on the map, one of my racing buddies hook me up on its first day. Haven't changed it since.
Edited by CZRoger, December 11, 2014 - 09:23 AM.
  • YzCas
Posted December 11, 2014 - 09:26 AM
I was just trying to be helpfull no need to get your panties pulled up to tight their chief.
Posted December 11, 2014 - 10:56 AM
Four-strokes have to get ridiculously lean before they hurt themselves from it.  By the time they are so lean that significant damage is a 50/50 possibility, they will run intolerably bad as a result.
  • rojapar
Posted December 11, 2014 - 11:13 AM
sure post it up...that would be great!
  • YzCas
Posted December 11, 2014 - 11:23 AM
Fuel these are all plus. These are are all plus timing
3 3 3.
4 4 3
4 4 3. 2 2 2
3 3 2
3 3 2
  • Hot  36 replies
  • Hot  47 replies
  • 9 replies
