wr 400 idle wont adjust down
6 replies to this topic
  • bozi
Posted December 03, 2014 - 12:47 PM
i have a wr 400 1999 that i have recentley rebuilt with new piston and valves, it has a dep 7 exhaust on it that is the only mod on it. The problem i am having is that i can start it without any choke on and no matter what i do with the fuel screw it makes no difference to the idle ihave gone from a stock 45 pilotjet to a 48 no change and to a 42 and 40 still no change i have sprayed wd 40 all over to check for air leaks but no joy in finding one . I have stripped the carb and checked the slide plate no cracks in it. the header pipe glows red as its revving high about 3000 to 4000 revs the only way i can slow it down is to pull the choke out half way and the header stops glowing but if i pull it right out it revs and if it goes all the way in it revs any he would be a great help
  • Krannie McKranface
Posted December 03, 2014 - 01:28 PM
Does it have a hot start
  • bozi
Posted December 03, 2014 - 01:45 PM
Yes it does have a hot start on the handle bars
Posted December 03, 2014 - 02:45 PM
You probably need to service the hot start: cracked cover, leaking plunger, corroded cable holding the plunger open, etc
  • bozi
Posted December 03, 2014 - 02:47 PM
I will disconnect it tomorrow and try it with out any on
Posted December 03, 2014 - 03:33 PM
Uh, that is not going to work. Won't change anything.
You have to service the components on the carb.
  • jackfly
Posted December 03, 2014 - 09:27 PM
Do yourself a favor and order an aluminium cap from Amazon. The plastic one can be a pain....
