2012 wr450
6 replies to this topic
  • marconrh
Posted December 02, 2014 - 07:22 PM
have stock wr450f with tailpipe peashooter removed..what tune should I use to get best all around performance..have programmable tuner and currently using aussie tune..any netter recomendations?
  • revelc
Posted December 02, 2014 - 07:25 PM
Best performance will come from changing the modes for the different types of riding you do.
  • yamahadude93
Posted December 02, 2014 - 07:50 PM
+1
  • offrd beatr
Posted December 03, 2014 - 06:07 AM
And get a real silencer.
  • revelc
Posted December 03, 2014 - 08:12 AM
The stock one can be modified if you're on a budget.
If not a good slip on helps. Not a lot, but it's noticeable.
I am skeptical about the expansion chamber headers as the stocker already has one.
  • marconrh
Posted December 03, 2014 - 08:31 AM
I have the stock silencer modified with the pea shooter removed and aftermarket insert installed. is the stock header the same as the fmf powerbomb? it looks the same. is it worth the money for full exhaust or just replace the stock silencer with fmf and use stock header?
  • offrd beatr
Posted December 03, 2014 - 09:18 AM
Modified by making bigger holes in the baffles inside. You can't make it run with half inch diameter tubes.
