2010 450 wheel compatibility help?
9 replies to this topic
  • defiantk
Posted November 24, 2014 - 09:50 PM
Are 2010 yz450f rear wheels the same as earlier years (99-20??) wheels? Same rotor to sprocket spacings, same diameter axle, use the same disks?
Any differences?
Read thru the wheel interchange thread but couldnt find the answer.
Posted November 26, 2014 - 08:14 AM
No. The rear axle size was increased from 22mm to 25 in '09.
  • defiantk
Posted November 29, 2014 - 03:31 AM
Thanks, but I take it thats the only change? Using on a 20mm axle bike so im making reducer/spacers anyways
  • Monk
Posted December 08, 2014 - 06:44 PM
You'll need a whole sleeve to go completely through the wheel...
Edited by Monk, December 08, 2014 - 06:45 PM.
  • flapwick
Posted December 09, 2014 - 06:57 AM
Ten dollars for spacers from TUSK.
  • Monk
Posted December 09, 2014 - 06:15 PM
Do the spacers go inside the bearings?
  • flapwick
Posted December 09, 2014 - 08:05 PM
Yes.
  • flapwick
Posted December 09, 2014 - 08:07 PM
I posted some pictures on a previous thread on here somewhere.
Edited by flapwick, December 09, 2014 - 08:10 PM.
  • Wiz636
Posted December 10, 2014 - 06:02 PM
Are the hubs the same from '09 - '14?
Is the rear axle diameter the only change, i.e., are sprockets and discs interchangeable from '98 - '14?
Posted December 11, 2014 - 08:06 AM
Same hub through those years.
Sprockets have been interchangeable since at least '98.  The discs were changed somewhere around 2000, as I recall, and later in '07, but the first change was a quarter inch in diameter, or something as small as that, and the second was to go to the "wave" design.  All of the ones since the first change at least are interchangeable.
  • Hot  113 replies
  • 5 replies
  • 0 replies
