Fork fluid levels
1 reply to this topic
  • sjwr450
Posted February 04, 2004 - 05:32 AM
I have my WR450 in the shop getting a fork seal replaced and fluid changed. I weigh 175. Should I change height of fluid? Also I have my buddies WR426 in the shop for samething but he is 225. Any thoughts. Thanks
  • MN_Kevin
Posted February 04, 2004 - 05:47 AM
raising your oil level will reduce bottoming. Don't do it unless you are bottoming. Occasional (not severe) bottoming is OK >> it shows you are efficiently using up your suspension travel.
