09 jetting question
No replies to this topic
  • rhinoracin
Posted November 22, 2014 - 07:27 PM
Before my last ride I put in a 42 pilot jet (from the stock 45) because it was recommended on here. I turned the fuel screw out a little and when riding, there would sometimes be a slight hesitation in 1/8-1/2 throttle openings. My bike also bogged a couple times when opening the throttle fast, which it has never done. I know it probably isn't the leak jet, because I have a R&D power pump/spring kit with the right adjustment (about #60 leak jet). I know I might need to turn the fuel screw out more, because it's only about 1.5 turns out.
With the smaller pilot jet, the bike's starting/choke/idle seem better than before. But I'm assuming I need to raise the needle to get rid of the hesitation/bog, that's what I did when I went down from a 48 pilot and it helped. My question is how much should I raise the needle...1 or 2 clips?
My current jetting is 42 pilot, 165 main, NFPP needle 4th clip (for SoCal deserts).
  • On January 15, 2017
Motocross
  • Hot  491 replies
  • Hot  113 replies
