07 YZ450F - Timbersled Snowbike / Dual Sport / Mountain Singletrack - Buildup
19 replies to this topic
  • n16ht5
Posted November 12, 2014 - 09:16 PM
Two months ago I picked up a 2007 YZ450F for a Timbersled host in WA state. It was in need of a top end so I got it for a decent price of $1300. My plans were to rebuild it, get a license plate on it for summer singletrack / DS and run the Timbersled in winter.
Other than the PMB spark arrestor, skid plate, JD jetting kit, and an extra oversize tank, it was stock.
I had an 07 WR450F that I tried to make into a do-it-all bike, but it suffered from being too heavy and poorly suspended. This bike should be the ticket.
I only rode it around in the yard, barely enough to get it to third gear... time to strip it down
And pick up a 2014 Timbersled LT
Split cases for new crank and WRF 1st and 5th gearsets
Took a flap disc to the frame. I like it. My CR250 is polished but it is too much work to keep shiny
 /s1152/_MG_6698.JPG]
Edited by n16ht5, November 13, 2014 - 05:14 PM.
  • n16ht5
Posted November 12, 2014 - 09:17 PM
WRF gears put in.. time to reassemble. New stainless Kibble White exhaust valves / springs as well (OEM Intakes looked good). Wiseco hi compression piston. New seals, etc
While assembling, I installed a Ricky Stator 35W lighting stator.
30W led light bar
Crankcase breather to airbox
Wire loom... red cord is for rear turn signals + tail light. There is also a 12V acc plug and power to heated grips
Small 39,000 uF capacitor + CDI unit here. I am going to run a regular headlight for DS inspection, so it would be in the way in stock location.
I also used a scooter 100CC recitifer / regulator off ebay, which I put in between the rear upper motor mounts under the tank.
HOLESHOT Smart Pad for my GPS android phone running MyTrails. Also, heated grips and dual sport switch
25A fuse from stator
PMB spark arrestor + 07 pipe = quiet
lighted switch for grip heaters.
wire umbilical
Winterized finished product.
With Moose hand guards. I still need to cut some buckets up for deflectors. Flatland Racing skid plate + Radiator guards
Tail light / headlight / turn signals will come next summer when the tires go back on :)
Edited by n16ht5, November 12, 2014 - 09:20 PM.
  • YzCas
Posted November 13, 2014 - 04:22 AM
30W led light bar
wire umbilical
Now that looks like it would be fun are Theye fast?
  • YamaLink
Posted November 13, 2014 - 06:58 AM
Excellent project and great job on the pics/workup report!
  • Arctic Pride
Posted November 13, 2014 - 07:03 AM
Nice job, I think this is the best way to do a timbersled conversion (rebuild), keep updating on its performance e/t/c...Do you have seat time on snowmobiles as well?
  • n16ht5
Posted November 13, 2014 - 05:06 PM
They are the most fun you can have.. period. OK, I think a wing suit ..might be more fun.. Last spring on top of a volcano
  • n16ht5
Posted November 13, 2014 - 05:13 PM
Thanks OK.. yes -->
  • n16ht5
Posted November 13, 2014 - 05:19 PM
Transmission Swap-
I purchased parts from Partzilla
WR transmissionicon1.png parts list
axel main 5TJ-17411-20-00
5th pinion gear 5TJ-17151-20-00
3rd pinion gear 5TJ-17131-20-00
4th pinion gear 5TJ-17141-20-00
2nd pinion gear 5TJ-17121-20-00
1st gear wheel 5TJ-17211-20-00
5th gear wheelicon1.png 5TJ-17251-20-00
3rd gear wheel 5TJ-17231-20-00
4th gear wheel 5TJ-17241-20-00
2nd gear wheel 5TJ-17221-20-00
You'll have to add new head and base gasketsicon1.png also.
This adds about an additional 16mph over stock gearing and makes 1st alot lower.
  • n16ht5
Posted November 13, 2014 - 05:25 PM
Dual Sport parts-
Ricky Stator 35W stator - Rickystator.com
Lighting - Cyclopsadventuresports.com
Turn Signals - http://www.ebay.com/itm/171173815834
Tail Light - http://www.ebay.com/...=STRK:MEBIDX:IT
Mirrors - http://www.ebay.com/...=STRK:MEBIDX:IT
Switch - http://www.ebay.com/...=STRK:MEBIDX:IT
Headlight - http://www.ebay.com/...2e76c6c&vxp=mtr
Capacitor (Stores energy like a battery, but lighter and no maintenance) - http://www.ebay.com/...=item4d11385265
Rectifier / Regulator (convert AC to DC and regulate power) - http://www.ebay.com/...7c88589&vxp=mtr
Edited by n16ht5, November 13, 2014 - 05:27 PM.
  • Dennish87
Posted November 16, 2014 - 12:36 PM
I'm looking to put a stator and headlight on my 07 yz450f. But when I go to rickystator's website I can't find any stator that will fit my 07. How did you get a stator from them?
  • n16ht5
Posted November 16, 2014 - 07:29 PM
http://www.rickystat...100f5750cef0b3d
Finished the bike up today
12V cigarette lighter plug + phone charger port, rubber sealed covers on the outlets (look on handlebar left of crash pad)
http://www.ebay.com/...97b6023&vxp=mtr
Tractor manual holder tube - for stowing rope nice and dry
Finished hand guards
Edited by n16ht5, November 16, 2014 - 07:30 PM.
  • Dennish87
Posted November 17, 2014 - 03:47 AM
What is the capacitor for or what does it do? Also do I need a capacitor and regulator or can I simply wire the headlight right to the stator? I'm sorry for all the questions, but don't have any experience with this particular topic. I might run an led taillight but for now I just need a headlight so if I can make it home of I'm out a little after dark. I'll also use a on/off switch for the lights do its not constantly on. Thank yiu for your help.
  • Arctic Pride
Posted November 17, 2014 - 07:21 AM
are your hand guards cut up taping compound buckets? :smirk: pretty genius, get some better coverage too...
  • n16ht5
Posted November 25, 2014 - 10:11 AM
capacitor acts as a battery. You need a rectifier/regulator. I listed everything you need above, you will probably need to google the items to see what they are and how they work..12v electrical basics
bike ran great, a bit fat on the low/mid so I backed the pilot down to the stock 45 and main still at 160, 1-3/4 turns out.
  • Arctic Pride
Posted November 25, 2014 - 10:22 AM
does it trench dig worse than a sled in the deeper stuff?
  • 700rScott
Posted August 28, 2015 - 11:41 AM
How's the ricky stator holding up? I'm looking to add one to my 06 yz450
  • cpetz24
Posted August 28, 2015 - 12:30 PM
I really like the project! Pictures were great, but why would you spend all the time and money to make the bike that solid and look that good and then cut up buckets for hand guards!! lol Not a bad idea, but it would look so much better with even just a cheap set of real guards.
  • n16ht5
Posted September 08, 2015 - 08:33 AM
no, usually you can just rock it back and forth and ride right out. 10000x less work getting out.
Ricky stator is still good.
bucket busters are legit man. Ask Scott Summers
  • -MORK-
Posted September 10, 2015 - 02:29 PM
Did you ever mount that eBay KTM headlight? I'm curious to see how you did that.
  • JKoz
Posted October 08, 2015 - 06:11 PM
Great build, pics and info. No time for projects so I'm considering buying a new 450 and timbersleds LT kit.
I sold my last bike a couple years ago and regret it so I'm debating on selling my snowcheck Polaris SKS155 and doing a snowbike. My kids and I want to get back into dirt bikes anyways.
Nobody I ride with has one and most of us are getting new sleds this year. We aren't trail riders however we do live in Michigan so we do have to ride some trail to get to our play areas. Just wonder how slow this setup would be riding with a group of sleds.
Motocross
  • Hot  491 replies
  • Hot  47 replies
  • Hot  33 replies
  • Hot  36 replies
