2001 yz426f still no spark.
2 replies to this topic
  • psmith994
Posted November 11, 2014 - 02:31 PM
Cdi changed. Grounds checked. All electronic components check for proper ohm readings. All wires checked. Tps checked. I have signal from the stator pickup to the cdi but nothing past the cdi. Please help.
  • psmith994
Posted November 12, 2014 - 12:49 PM
Wow...nothing. that sucks
Posted November 12, 2014 - 04:52 PM
If you have checked all three coils on the stator (source, exciter, and trigger coil), the ignition coil, the TPS, and the kill switch, and you have tested each of the wires in the harness for continuity from end to end, then it's likely to be the CDI.  But only if.
  • 0 replies
  • 5 replies
  • Hot  36 replies
  • 10 replies
