15 yz450 suspension
4 replies to this topic
  • tjhooker
Posted November 10, 2014 - 12:15 PM
The initial part of the stroke on the forks feels harsh especially on all the small bumps do Ya think softer springs would fix it ?
5'7" 165 novice mostly motocross intermediate terrain 110 mm sag
  • Krannie McKranface
Posted November 10, 2014 - 01:51 PM
This is the WR forum, not the YZ forum
You never change springs to change the stiffness of the suspension.
You need to change springs only for sag numbers
You have a track bike, so if you are not riding it wide open, it will feel harsh
You would need to re-valve the mid-valve and change it's float, in order to change low-speed damping
Set your sag, break in the suspension, dial out the clickers a few clicks.....first.
  • YamaLink
Posted November 10, 2014 - 04:06 PM
Did anyone change the high-speed compression? And where are your clicker settings right now?
  • tjhooker
Posted November 11, 2014 - 06:27 AM
Clickers are all stock I tryed going softer on compression on the forks but it made it worse
  • Monk
Posted November 11, 2014 - 06:40 AM
Yes, because the fork sit lower in the stroke on the firmest part of the suspension....
