Can't get my 2006 yz450f to run...
2 replies to this topic
  • mcovey208
Posted November 07, 2014 - 11:26 AM
Hi there,
     I'm no mechanic, but I've had success with rebuilding things in the past so I figured this wouldn't be too bad. I was wrong. I recently purchased a running 2006 yz450f from a co-worker and he suggested that I replace the cylinder and piston before doing any heavy riding. He came to this conclusion from recently having it apart and installing a new timing chain among other things. When I got it, it would start right up and had zero issues with plenty of power. I've since replaced the piston and cylinder and now it won't run. I've not tampered with anything else and put everything back EXACTLY as it was before so I'm stumped. Timing is absolutely perfect without a doubt. A couple of times it would start for a split second then die. Occasionally there is a pop when kicksarting (assuming a backfire), and it constantly leaks gas when I'm rapidly trying to kicksart it. Can't get it to fire anymore at all. Don't know what to do so any advice would be helpful. Thanks!
                                -Mike
  • LoonRider
Posted November 07, 2014 - 12:21 PM
Where is the gas leaking from?
Check for spark, gas getting to the cylinder, and air.
Did you install the rings the right way? You said you're not a mechanic but said you put everything back The exact way it was.
Is it possible you mixed up the exhaust and intake shims? You might want to take off the valve cover and check the clearances.
Posted November 07, 2014 - 08:48 PM
Your trouble is more likely to be in the carb than anywhere else.  If it sat more than 6 weeks in the summer, you can be just about certain that the pilot jet is blocked with dried fuel varnish.  Fuel gum is probably behind the gas leakage, too.  The float may be physically stuck.
  • 5 replies
  • On January 15, 2017
  • Hot  38 replies
  • Hot  113 replies
