Replacement Chain
17 replies to this topic
  • cubera
Posted November 07, 2014 - 10:09 AM
What is the stock chain on the WR450F 2013 and what replaces it? I usually run RK chains but does the WR require a narrow chain, for example. Thanks for the education in advance :goofy: . I have over 100 hours on the "new" WR and it's running great.....just the chain is worn out. :ride:
  • vlxjim
Posted November 07, 2014 - 10:48 AM
Just a 520 chain of your liking. I would get a O OR X  ring chain. RK or DID are great chains.
Edited by vlxjim, November 07, 2014 - 10:48 AM.
  • woods-rider
Posted November 07, 2014 - 10:54 AM
Stock is a 520 O-ring chain.
  • cubera
Posted November 07, 2014 - 11:50 AM
Thank you, Sir. I'm happy a narrow 520 is not mandatory. I can stick with my usual RK X ring chain then.
  • Swappa
Posted November 10, 2014 - 02:15 PM
F150joker style (fellow tt member) installed an RK GB520GXW on his 2009 YZ450.
http://www.outlawrac.../52chmali3.html
He replaced it (before it wore out) with the RK GB520MXU because it was lighter, not much more money and quite a lot narrower. He was racing/riding in the desert on his YZ.
http://www.outlawrac.../52chmali1.html
There might be more clearance in the stock chain guide with the smaller chain.
  • cubera
Posted November 10, 2014 - 02:25 PM
The 520MXU is rated at 9,000 pounds while the 520GXW is 8,500. But too late I already installed the new GXW. Next time around I'll definitely be looking at the MXU though!
  • Swappa
Posted November 10, 2014 - 02:30 PM
No problem. You can't go wrong with RK chains ... they're just like Excel rims ... the gold standard.
FWIW, the DID VT2 and Sunstar XTG are both 4.4 lb and the RK 520MXU is only 3.8 lb @ 120 links. Not sure what the GXW weighs in at, but probably 4-5 lbs.
Edited by Swappa, November 10, 2014 - 02:31 PM.
  • cubera
Posted November 10, 2014 - 02:34 PM
Good question. I know the GXW is heavy I'm sure in the 4-5 pound range. I'll look it up.
  • cubera
Posted November 10, 2014 - 02:41 PM
The GXW 520 is 3.75 pounds per 100 links and the 520MXU is 3.10 pounds for 100 links. So the 520 GXW is 4.275 pounds for 114 links. :ride:
  • Krannie McKranface
Posted November 10, 2014 - 06:43 PM
VT-2 or nothing
400 hours easliy
  • stevethe
Posted November 10, 2014 - 07:05 PM
Just bought a DID VR3 and my arse still hurts.
  • stevethe
Posted November 11, 2014 - 09:06 AM
Anybody know of the best counter shaft sprocket. I used what was in my parts bin, forgot who made it.  My last one bent the teeth. I think that the counter shaft sprocket sprocket is the weak link for a really good chain and Supersprox rear.
Posted November 11, 2014 - 09:11 AM
JT
  • stevethe
Posted November 11, 2014 - 11:05 AM
JT
Good company.
Thanks,
  • Swappa
Posted November 11, 2014 - 12:36 PM
Well off topic of the OP ... FWIW, Sunstar and Talon have both outlasted OEM and JT for me.
  • Texas2Smoker
Posted November 11, 2014 - 01:02 PM
I like X-ring chains for the durability
  • Spud786
Posted November 25, 2014 - 03:37 PM
Run the heaviest strongest chain that you can buy, if you like your pocketbook. Weight savings isn't worth it, if you pay for your own parts and ride a lot.
  • Yzfracer
Posted November 30, 2014 - 08:00 PM
Regina ORN6 o-ring . Excellent has lasted 2 years so far!!!!!!!!
