DIY rubber mount bar clamps for 06 yz450
6 replies to this topic
  • 78sharpshooter
Posted November 05, 2014 - 01:05 PM
Wondering if the stock top clamp and bar mounts can be converted to rubber mount. Was thinking of longer bolts and milling the mount holes of the top clamp; either conical or flat with high durometer rubber bushings.
  • ekulb14
Posted November 05, 2014 - 07:26 PM
yes im sure they could be converted, if you like to tinker with that sort, but im gonna go out on a limb here and say some pillow tops are a easier fix , maybe fast flexx bars if you want to spend a lil to fit the problem with out any milling.
  • xXHaNsEnXx
Posted November 06, 2014 - 09:04 PM
  • xXHaNsEnXx
Posted November 06, 2014 - 09:06 PM
ImageUploadedByThumper Talk1415336684.436087.jpg i had to do it on my 07
  • 78sharpshooter
Posted November 07, 2014 - 06:08 PM
How did you do it and which protaper clamps did you use? Did it make a difference?
  • xXHaNsEnXx
Posted November 07, 2014 - 07:22 PM
I bought the pro taper mounts for a Honda and drilled out the holes. Then tapered the top of the holes to seat the rubber mounts
  • xXHaNsEnXx
Posted November 07, 2014 - 07:25 PM
If I remember right the oem yamaha mounts were like 160 for a pair. The pro taper mounts were 40. For some reason no aftermarket mounts were made for a 07. Not that I could find or my dealer anyway.
