Normal Operating Temperatures
5 replies to this topic
  • Hoosier-Daddy
Posted November 04, 2014 - 01:56 PM
I just rebuilt my water pump after i found coolant seeping from the weep hole and think the bike is good now but looking for a little help.
What are the normal temps of the cylinder, head, and radiators if I shoot them with a pyrometer?
It is not possible for the side cover and pump cover to go back together without the impeller shaft being in the slot that drives it is it?
I ask because it seems like the bike got hotter faster when I fired it up (not moving) to check for leaks.
Posted November 04, 2014 - 03:39 PM
The operating temperature range is hugely dependent on the outside air temp and the speed at which you are traveling at the moment.  The bike has no thermostat and no fan, so it has no way of managing that on its own.
In "normal" riding weather, while moving at, say, 30 mph, "normal" water temps could be around 135 degrees Fahrenheit, give or take as many as 40 either way.  Obviously, if you cap is good and the coolant is a standard 50/50 EG or PG and water mix, and you see the cap releasing, you've reached 270.   The first guys who rode EFI YZ's in the snow found they had to cover one radiator in order to get the fuel system out of the extra rich "cold engine mode".  Temps never got up to 100 otherwise.  What I'm saying is that your question doesn't have a pat answer, just exactly.
The impeller shaft tab being out of alignment will prevent the cover from installing unless you pulled it down with the screws, in which case, you could possibly force it to close up in spite of the tab.  I doubt you would have done it that way, though.  You can check it for proper engagement by laying the bike on its left side and opening the small pump cover.  You won't loose much coolant (remember to release any pressure in the system first).  And, it is normal for the impeller to rotate an eighth turn or so in its slot.
  • Hoosier-Daddy
Posted November 05, 2014 - 05:47 AM
I did make sure the cover was all the way down before bolting to make sure I didn't pinch the oring.
The small cover you are talking about removing with bike laying down is the one with the oring and 4 bolts (one of which is the drain)?
I did a search and dug up a pic of the seal orientation you posted in the past. That was helpful because the seal on the bearing side was unrecognizable by the time I drove the old bearing out.
Posted November 05, 2014 - 07:34 AM
Yes.  You can release the cooling system pressure and start the bike, then remove the cap.  Circulation should be obvious if it's happening, which will tell you that the pump is turning.
  • Hoosier-Daddy
Posted November 05, 2014 - 07:45 AM
Release the system pressure by loosening rad cap but not removing or crack open small drain bolt?
Posted November 05, 2014 - 12:56 PM
Cap's easier and less messy, normally.
  • Hot  30 replies
  • Hot  113 replies
  • Hot  47 replies
  • 0 replies
