400 head on a 426?
9 replies to this topic
  • rileyp
Posted November 04, 2014 - 02:46 AM
Hi my 426 head is dead.. I can get 400 head nearby possibly at the right price.
1 Will it fit ?
2 Do I need a 400 or 426 gasket?
3 will it effect compression ratio ?
  • hooliganone
Posted November 04, 2014 - 07:22 AM
Yes it will work, I'm running that set up right now. The hot start sys. is different so there is a hose barb on the back of the head, that you can just use a vacuum plug on. The gasket i used I can't remember if I used the 426 or the 400. I have been running this setup for about a year and a half with no problems.
  • rileyp
Posted November 06, 2014 - 10:31 PM
Thanks for responding :)  Does it affect compression ratio?  The 400 head has a smaller diameter machined out section. So it would increase compression i would think...
  • hooliganone
Posted November 07, 2014 - 07:18 AM
I think the compression is the same at 12.5:1, but the bore of the jug is different.
Posted November 07, 2014 - 07:31 AM
Using the 400 head on a 426 cylinder should raise the compression to about 13-13.2:1, due to the smaller combustion chamber volume.  That's a rough calculation, but it should be pretty close.
  • rileyp
Posted November 07, 2014 - 04:15 PM
Will increasing the compression ratio have any ill effect and would I need to do anything to to compensate for it?
Ive read a little and I would need to run higher octane fuel is this correct?
Normal fuel in Aus is only 91-93
Edited by rileyp, November 07, 2014 - 07:59 PM.
Posted November 08, 2014 - 10:28 AM
Is that 93 Research Octane, Motor Octane, or the US "anti-knock index"  (an average of both methods)?  The manual requires 95 octane by the Research Method.  That's about 87 Motor Octane, and about 91 on the US AKI.
If you ran OK at the stock CR, you'll probably be alright at 13.2, but pay attention to it at lower RPM at first.
  • rileyp
Posted November 08, 2014 - 02:35 PM
Thanks for your help hooliganone and greyracer :)
In Australia
"Australia: "regular" unleaded fuel is 91 RON, "premium" unleaded with 95 RON is widely available, and 98 RON fuel is also reasonably common.
All fuel in Australia is unleaded except for some aviation fuels."
http://en.wikipedia....i/Octane_rating
Edited by rileyp, November 08, 2014 - 02:43 PM.
Posted November 09, 2014 - 08:26 AM
95 RON should be all you need.
  • rileyp
Posted November 09, 2014 - 11:11 PM
  • Hot  50 replies
  • Hot  113 replies
  • Hot  38 replies
  • Hot  30 replies
