Swingarm bolt stuck
24 replies to this topic
  • ar2stroke
Posted January 08, 2015 - 02:01 PM
#21
Pulled out the big guns on that job, likin the pics!!!
The big sledge was like the last straw!
:smashpc:
  • JorisBoris
Posted January 08, 2015 - 04:33 PM
#22
I did exactly al that... the press, a bolt to pull... did nothing ! Cutting will be the final option.
  • bobpara
Posted January 09, 2015 - 12:48 PM
#23
Even the radiator and Oil might leak out if I have to tip it too far over
  • bg10459
Posted January 11, 2015 - 07:20 AM
#24
Lay it on its side. Block up underneath the frame
Use penetrating oil, heat and time
Leave the swing arm nut on but loose.
Hit it with a big hammer
Fully tighten the nut then loosen again ( this is key)
Rinse and repeat.
Leave the cutting wheel in the toolbox
  • woods-rider
Posted January 11, 2015 - 08:15 AM
#25
Rinse and repeat.
I tried that for 7 days straight with a minimum of 3 heat cycles per day. It didn't budge. If you are careful with the cutoff wheel it's really not a bad option. I got a like-new swingarm bolt off eBay for like 5 bucks shipped. I wish I would have just cut it off the first day instead of wasting 2 weeks trying to get it out with saving the bolt.
After that experience I now grease all my chassis bearings when the first snow hits in the hills around here. since the snow usually only lasts for a week or two it usually works out perfectly and I don't miss any riding.
