2003 WR450 oil line on left side leaks
2 replies to this topic
  • WR_Bill
Posted October 31, 2014 - 02:02 PM
I changed the oil on my 2003 WR450 and loosened the oil line on the lower left side.  Put it back together using the dowel and the o ring.  It leaked a little, took it back apart and replaced the o ring with one o-ring I had on hand, put it back together  and is still leaked.  So I ordered the OEM replacement - still leaks.  I did not notice any major scratches on the aluminum case of the aluminum fitting.  Should I put some RTV on the aluminum fitting, let it dry and try again.  Anyone have a similar problem? or advice.
Thanks in advance
Edited by WR_Bill, October 31, 2014 - 02:42 PM.
  • DeepPurplishBlue
Posted October 31, 2014 - 06:40 PM
Had this problem before on my 03... ended up putting two o-rings on it. Hasn't leaked a drop in years.
  • WR_Bill
Posted November 10, 2014 - 06:36 PM
Double o-rings worked great - thanks for the help
