Yamaha wr 426 hotcam
2 replies to this topic
  • carlloktm
Posted October 30, 2014 - 09:08 AM
Hi everyone
I'm wondering if it's worth fitting a stage 1 exhaust hot cam to my wr?
Apart from the auto decompression will there be any power gains ?
Also will I need to re shim the valves ?
Appreciate any help
  • stevethe
Posted October 30, 2014 - 10:42 AM
Probably get a little more top end. Definitely you need to check or shim the valves.
  • Pooley
Posted October 30, 2014 - 12:24 PM
I just did this over the summer.  This was my feelings after the work was done.  http://www.thumperta...-make-me-smile/
Always check and re-shim your valves if you change any parts on the top end.  Quick and easy to do, whereas damaging the top is expensive and time consuming to fix.
