'12+ WR450F Sprocket Replacement Tips 'n Tricks Request
9 replies to this topic
  • mebgardner
Posted October 28, 2014 - 08:50 AM
I'm getting set to replace the front and rear sprockets for the first time. I've done this on other cycles before, but not this one.
So, could I get the "short list" of R+R Tips 'n Tricks?
Is the front sprocket a reverse thread? Is there any locker compound used by the OEM, or do I put any on during the replacement?
I usually stand on the rear brake and use a breaker bar with a 1/2 in drive to break the CS nut loose. Good enough?
I know to inspect the oil seal behind the front sprocket, and look for wear on the steel cylinder that the oil seal presses against.
I know not to re-seat the oil seal too deep, that there is no "bottom" depth to re-seating it. It seats to "not past flush" depth.
I think I inspect the rear wheel bearings while I'm at it, and re-grease them?
Do I need any consumables? A new locking tab ring for the CS nut?
Anything else I should know before I get in there?
Posted October 28, 2014 - 11:28 AM
No. Right hand threads.
No. There is a locking tab washer, however.  Thread locker is not required if properly installed
Usually.  if it's exceptionally stubborn, you can run a bar through one of the holes in the rear sprocket and the spokes so it lays atop the swing arm to positively lock the wheel.
Both good things.  If you remove or replace the collar, be sure you replace the O-ring underneath it on the output shaft
Some rear wheel bearings are sealed bearings.  The seals can be carefully picked out for such service
Replacement of the tab washer is not usually needed, but they're cheap.  Get one and keep one or the other for next time.
  • mebgardner
Posted October 28, 2014 - 12:21 PM
Is there a way I can tell if I'm looking at a sealed bearing or not?
I've seen them while working on cars / trucks, but never cycles.
  • Krannie McKranface
Posted October 28, 2014 - 01:05 PM
If you can't see the bearing, only the bearing housing, they are sealed.
  • mebgardner
Posted October 28, 2014 - 02:01 PM
This statement.  Does this include a collar removal to just inspect the O-Ring?
That is, if I remove the collar to inspect the O-ring underneath it (and the collar for indented wear mark), then I "need to be sure to replace the O-ring..."
I think what I'm asking is, if I go in there, I'll need to replace the O-ring in any case?
Do I understand that right?
Thank you.
... and thank you, sir, for your help.
Posted October 28, 2014 - 02:02 PM
Open bearing:
Sealed bearing:
  • mebgardner
Posted October 28, 2014 - 02:04 PM
Open bearing:
Sealed bearing:
Beauty. Very nice.  Thanks so much. Really, I mean it (no sarcasam).
Posted October 28, 2014 - 02:06 PM
...if I remove the collar to inspect the O-ring underneath it (and the collar for indented wear mark), then I "need to be sure to replace the O-ring..."
If the collar remains in place, and there's no evidence of a leak, the O-ring can be left alone.  As I understand it, you don't have a leak now, so although you could simply replace the O-ring anyway, there's no indicated need to unless you disturb it.  Even then, you'd likely be able to reuse the ring.  It's just so cheap that there's no reason not to if it's out.
Regarding bearing seals as shown above, should you try to remove them, do so from the outside edge.  Don't pick or pry at the inner diameter, as that is the sealing lip.
  • mebgardner
Posted October 28, 2014 - 03:19 PM
Do you have a gut feel about whether or not this should be done? Or, how often?
...and , correct: I do not have any evidence of an oil leak from the CS seal (or any leak for that matter).
Posted October 29, 2014 - 06:09 AM
Once a year,  ...ish.  More often if you're in mud all the time and wash the bike with pressure.
