Sprockets: What Mfgr do you buy / mount?
Drive Sprockets
28 replies to this topic
  • RockerYZWR
Posted October 27, 2014 - 08:42 PM
#21
Supersprox. Six desert races and 50+ hours of training and play riding this year with lots of sand track and dunes. Honestly minimal wear - although I'm religious with maintenance after just about every ride, I'm still impressed even if it is steel. Nice looking product, too.
  • mch
Posted October 27, 2014 - 09:11 PM
#22
I just swapped out my chain and sprockets about a month ago.  My bike (12 WR450) has about 350-400 hours and this is my 1st chain and sprocket change.  the stock stuff held up great (No chain lube - just WD40 on chain) and the stock chain/sprockets probably had a few more months before it really needed replacing.
I just put this stuff on, hope it holds up:
Primary Drive 520 ORH Gold X-Ring Chain 520x114
Supersprox Rear Aluminum Sprocket 50 Tooth
Supersprox Front Sprocket 13 Tooth
Supersprox Sprocket Bolt and Nut Kit
  • KennyMc
Posted October 28, 2014 - 05:50 AM
#23
I have had the Ironman sprocket on my bike for 3 years. I have no idea if it has taken any direct hits but I ride in the rocks for the most part. I now have a Supersprox as I changed the gearing and liked the "bling factor". It has held up great for the last year.
  • mebgardner
Posted October 28, 2014 - 08:54 AM
#24
I wish I was getting this kind of mileage.  I'm maybe 40 hours into this cycle and the front and rear both need replacement.
I hose off the cycle after every ride, and I clean and lube the chain pretty regularly. So, I dunno.  It must be the deep sand what got me.
  • beezer
Posted October 28, 2014 - 08:58 AM
#25
I never use chain lube.
After a wash I run the bike up and down the block and hit it with WD-40.
  • YamaLink
Posted October 28, 2014 - 12:23 PM
#26
Renthal and Primary Drive are good options for my needs.
  • KennyMc
Posted October 28, 2014 - 01:18 PM
#27
That's all I've done for years. O ring chain.
Edited by KennyMc, October 28, 2014 - 01:21 PM.
  • stevethe
Posted October 28, 2014 - 03:01 PM
#28
One of the keys to longevity is also a good x ring chain. The stock O ring chains seem to kink real bad.
  • DonnieD
Posted October 31, 2014 - 10:41 AM
#29
I haven't had my WR long but I use the Dupont chain saver. Goes on wet and dries in about 30 minutes. I add this to a clean chain of course.
I think it's probably more of a protectant than lube. But I changed my street bike chain/sprockets at 40K using it and there was still life in the hardware. That's quite a bit of miles, most with my bike probably change around 30K.
