2008 WR450F fork revalve - Converting rebound mid-valve to check valve
2 replies to this topic
  • Ledrocnoc
Posted October 24, 2014 - 04:21 AM
I am about ready to do install the RaceTech Gold Valve on my 2008 WR450F.  I have the shim stack and the instructions clarified by the RaceTech tech guy (the instructions they include with the kit aren't the greatest!)
The RaceTech tech wrote that to get the maximum effect I would have to open the cartridge and replace the Mid Valve to the Check Valve.  I was wondering if anyone has done that procedure and what the feedback was.
Looking at the instructions (again, not the most clear...), this looks more involved that I can do here with the means available to me.
Thanks.
Denis
  • stevethe
Posted October 24, 2014 - 05:19 AM
Thanks.
Denis
They said it wasn't necessary on mine however it may be dependent on what you weigh. It also takes special tools to take it apart.
  • GuyGraham
Posted October 24, 2014 - 10:49 AM
I did mine
Yes its a bit scary but you can do it
Tommy bar through the holes in the end of the cartridge and then use the tool you used to hole the cartridge when taking forks apart, to unscrew the to top bit from the cartridge tube
Its tight!
I ended up adding more shims to the rebound stack inside the cartridge when I went to the 0.46 springs
Edited by GuyGraham, October 24, 2014 - 10:51 AM.
