Front caliper spring
5 replies to this topic
  • CZRoger
Posted October 15, 2014 - 12:40 PM
'14 YZ450F... While replacing the front brake pads, didn't notice the spring had hit the floor. Consequently stepped on it :facepalm: , now deformed and won't fit properly. Cannot get it back into proper form. Not in stock at my local dealer.
This is the spring/bracket thing that fits above the pads to provide tension to the pads I presume. Can I run without it and not cause damage?
  • drtrcr400
Posted October 15, 2014 - 02:24 PM
As long as it's not the shim you'll be fine for a while until your dealer gets it in.
  • CZRoger
Posted October 15, 2014 - 02:35 PM
This is the part in question...
5DH-25919-00-00 Support, pad
  • drtrcr400
Posted October 15, 2014 - 02:44 PM
It's not going to have immediate negative effects if you run without that for a bit IMO.
  • CZRoger
Posted October 15, 2014 - 02:58 PM
That's what I thought as well. Thanks
Posted October 16, 2014 - 06:42 AM
If that's the lower of the two springs as the part number indicates, it is mostly for the purpose of keeping the pads from rattling around while not braking.  Better to have it, but not critical.
Need help by Goforaride
  • Hot  68 replies
  • Hot  491 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • Hot  36 replies
