idle voltage at 13.5 v
6 replies to this topic
  • li54sa
Posted October 15, 2014 - 04:29 AM
hey guys.two days ago i change the battery on my wr450 2003.i decided to take some information about the voltage.on idle the bike produce 13.5 volt and when i raise the rpm to 5000 as manual writes it drops to 13.3 volts but it charges a bit slow.is that normal?when the bike is not working the battery is about 12.6-12.7 volt.d you think that the stator or  regulator have any problem?thanks a lot..
  • Krannie McKranface
Posted October 15, 2014 - 05:17 AM
It's a little low, as you should be able to get 13.7 to 14.0, but there are lots of variables, like a cold battery.
Charging won't occur untill you are over 4000 rpm, and is very slow.
Just try it and see.
  • li54sa
Posted October 15, 2014 - 05:32 AM
at 4000 rpm it shows 13.3-13.4 volt.at idle it shows 13.7-13.8.
Posted October 15, 2014 - 02:11 PM
Right, because, it is drawing current to charge the battery......
Spinning the motor faster does not create higher voltage.....that's what the regulator is for.
  • li54sa
Posted October 15, 2014 - 07:17 PM
yeah i know that but the manual writes that at 5000 rpm it should produce 14.1-14.9 volt instead of mine that produces 13.3-13.4 volt.is it normal?
  • stevethe
Posted October 16, 2014 - 07:00 AM
If your measuring off of the battery you probably wont show too much. The battery acts as a buffer and takes a while to go to a higher voltage. Just ride it if it stays charged it's good.
  • Spud786
Posted October 19, 2014 - 11:55 AM
The manual is correct , you have crap for voltage. you can easily lose a full volt through the various connectors from the stator to the RR , to the battery by having any resistance in those connectors.
