Automatic fan start
3 replies to this topic
  • s1lVa
Posted October 11, 2014 - 12:04 AM
Im going to install a SPAL fan to the wr450f, but im thinking about ways to make the fan go on automatic. I have no experience with this from past, but ive heard about radiator plugs.
Is this a plug thats NO before 95c, and goes NC after 95c and up? Where can this be fitted? are there other solutions? :) Thanks
  • Krannie McKranface
Posted October 11, 2014 - 05:35 AM
Use a Thermistor interupt on the power wire
They come readily set up for motor/auto use as a 'probe wire' or clamp
No need to read the water temp directly
http://www.trailtech.net/7500-3014
  • s1lVa
Posted October 11, 2014 - 09:16 AM
That is an accessorie to the TT Vapor, and has a variable resistance to measure the temprature. would be easier to get something similar that worked as an On/Off. Not interested in the temperature, just want the fan to go on when it needs to ^^
Posted October 11, 2014 - 03:13 PM
I didn't say a temp sensor, I said a Thermistor, which is a tempreture sensitive switch
